Use tweezers, or your fingers, to remove the bottom and top conductive fabrics or the loudspeaker cable adhesive if they're not intact.
Align the bottom loudspeaker conductive fabric on the underside of the loudspeaker.
Peel the clear liner off the loudspeaker cable adhesive.
Align the adhesive over the loudspeaker cable and lay it down, making sure not to cover the hole in the cable.
Align the hole in the loudspeaker cable over its peg on the frame.
Press down the cable with the tip of a spudger, or your finger, to adhere it to the frame.
Peel off the clear liner on the top loudspeaker conductive fabric.
Peel off the small colored liner covering the rounded corner of the fabric.
