Razer Ouroboros Scroll Wheel Replacement
  1. Razer Ouroboros Scroll Wheel Replacement, Scroll Wheel: step 1, image 1 of 3 Razer Ouroboros Scroll Wheel Replacement, Scroll Wheel: step 1, image 2 of 3 Razer Ouroboros Scroll Wheel Replacement, Scroll Wheel: step 1, image 3 of 3
    • Use a Phillips #00 screwdriver to loosen the two captive screws from the bottom of the mouse.
    • Slide the palm rest out of place.
  2. Razer Ouroboros Scroll Wheel Replacement: step 2, image 1 of 2 Razer Ouroboros Scroll Wheel Replacement: step 2, image 2 of 2
    Tool used on this step:
    Buy
    • Remove all of the stickers on the back of the mouse. After doing so, you should see six screws on the back of the mouse.
    • Use the Phillips #0 Screwdriver to remove all six of these 4mm screws.
    • Use the Phillips #00 Screwdriver to remove these two, 3mm screws.
    • Slide the side panels off of the mouse.
    • Use your tweezers to take the lock switches off of the mouse.
    • Using the T6 Torx screwdriver, remove the two bottom 4mm screws as indicated in the second picture.
  3. Razer Ouroboros Scroll Wheel Replacement: step 3, image 1 of 3 Razer Ouroboros Scroll Wheel Replacement: step 3, image 2 of 3 Razer Ouroboros Scroll Wheel Replacement: step 3, image 3 of 3
    • Using the T6 Torx screwdriver, remove the two 4mm screws hidden in the deep holes indicated in the first picture.
    • Slide the top panels off of the mouse.
    • Flip the mouse over, and the mouse casing should come off.
    • There are some connectors connecting the casing to the motherboard. They should slide off. Just be careful not to break them.
  4. Razer Ouroboros Scroll Wheel Replacement: step 4, image 1 of 3 Razer Ouroboros Scroll Wheel Replacement: step 4, image 2 of 3 Razer Ouroboros Scroll Wheel Replacement: step 4, image 3 of 3
    • Locate the 4mm screw indicated in the first picture, use a Phillips #00 Screwdriver to remove it.
    • Locate the two 4mm screws in the second picture, and remove those two with a Phillips #0 Screwdriver.
    • Now, you may remove the board that holds the scroll wheel and its components. Simply slide the wheel out and replace it.
    • Take note of the orientation in the final picture so that you can place the wheel back correctly into its mechanism.
5 other people completed this guide.
Preston Darling
372 Reputation
2 Guides authored
1 Guide Comment
Hello, one question, did the scroll click break, is it the same procedure?
Jorge Bestani (Ayman) - Reply
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 24
All Time: 4,503
