Introduction
This guide will help you replace the connection strip between the side buttons on the outer casing and the mouse itself. Be sure to use caution when unplugging the wires, for this could result in the mouse not working properly. Also use caution when removing the plastic shell, it is fragile and it could be cracked upon removal.
Peel back the two teflon tape from the top corners and the one larger one from the bottom with a spudger.
Gently remove the top plastic plate of the mouse.
Unplug the white cord from the circuit board.
Flip back the black plastic that holds the white connection strip in place on the side panel and the main panel.
Insert the blue striped ends into the white connection port on the mainframe as well as the frame with the buttons.
