Shop the Holiday Gift Guide
Razer Huntsman Mini Key Cap Replacement
View statistics:
Past 24 Hours:
8
Past 7 Days:
28
Past 30 Days:
125
All Time:
947
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 1 minute
Difficulty: Easy
Introduction
Go to step 1 ↓
Replacing a keycap on the Razer Huntsman Mini is a simple process that requires minimal tools. Before starting, unplug the keyboard from your computer to prevent any accidental inputs. Use a keycap puller, which is often included with replacement keycap sets, to remove the keycap you want to replace. Position the puller over the keycap, press down gently to get a secure grip, and pull upward with steady, even pressure. For larger keys like the spacebar or shift key, be careful of the stabilizers underneath, as they need to stay properly aligned for the key to function correctly.
Once the original keycap is removed, position the new keycap over the switch stem and press down firmly until it snaps into place. After replacing the keycap, reconnect your keyboard and test the key to ensure it responds as expected. The Razer Huntsman Mini uses standard MX-style stems, making it compatible with a wide variety of aftermarket keycap sets. While the keycap is removed, it’s a good opportunity to clean the area around the switch using a soft brush or compressed air to remove any built-up dust or debris. Properly maintaining your keyboard can extend its lifespan and keep it functioning like new.
Tools
    1. Razer Huntsman Mini Key Cap Replacement, Key Cap Replacement: step 1, image 1 of 1
      • Use a keycap puller or opening tool to remove the keycap(s).
      Ask FixBot
Cole Gagne
123 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 8
Past 7 Days: 28
Past 30 Days: 125
All Time: 947
