Razer Deathadder Essential RZ01-0254 Mouse Buttons Replacement
  1. Razer Deathadder Essential RZ01-0254 Mouse Buttons Replacement, Mouse Buttons: step 1, image 1 of 2 Razer Deathadder Essential RZ01-0254 Mouse Buttons Replacement, Mouse Buttons: step 1, image 2 of 2
    • Use a spudger or opening tool to remove the top skates from the mouse.
    • Poke a hole in the middle of the bar code to expose the 3 screws holding the mouse together.
  2. Razer Deathadder Essential RZ01-0254 Mouse Buttons Replacement: step 2, image 1 of 1
    • Use a Phillips #1 screwdriver to remove the three 9 mm screws that are holding the mouse together.
  3. Razer Deathadder Essential RZ01-0254 Mouse Buttons Replacement: step 3, image 1 of 3 Razer Deathadder Essential RZ01-0254 Mouse Buttons Replacement: step 3, image 2 of 3 Razer Deathadder Essential RZ01-0254 Mouse Buttons Replacement: step 3, image 3 of 3
    • Open the mouse, and use the Phillips #1 screwdriver remove the two 11 mm screws that are located on the left side of the motherboard.
    • Also, remove the single 4 mm screw next to the mouse wheel using the Phillips #1 screwdriver.
    • After you remove all three screws the motherboard should be free.
  4. Razer Deathadder Essential RZ01-0254 Mouse Buttons Replacement: step 4, image 1 of 2 Razer Deathadder Essential RZ01-0254 Mouse Buttons Replacement: step 4, image 2 of 2
    • This is the component that we will be replacing and its 3 contact points.
  5. Razer Deathadder Essential RZ01-0254 Mouse Buttons Replacement: step 5, image 1 of 1
    Tool used on this step:
    Desoldering Pump
    $3.99
    Buy
    • Using your soldering iron and desoldering pump, desolder the 3 contact points that attach to each button as marked.
    • Be careful when using a soldering iron, as it can burn you if not used correctly.
  6. Razer Deathadder Essential RZ01-0254 Mouse Buttons Replacement: step 6, image 1 of 3 Razer Deathadder Essential RZ01-0254 Mouse Buttons Replacement: step 6, image 2 of 3 Razer Deathadder Essential RZ01-0254 Mouse Buttons Replacement: step 6, image 3 of 3
    • Remove the button that you just desoldered.
    • Then solder the new button back into place. Repeat for both buttons.
  7. Razer Deathadder Essential RZ01-0254 Mouse Buttons Replacement: step 7, image 1 of 3 Razer Deathadder Essential RZ01-0254 Mouse Buttons Replacement: step 7, image 2 of 3 Razer Deathadder Essential RZ01-0254 Mouse Buttons Replacement: step 7, image 3 of 3
    • Return the motherboard to its original position, and replace the two 11 mm screws and the single 4 mm screw using a Phillips #1 screwdriver.
  8. Razer Deathadder Essential RZ01-0254 Mouse Buttons Replacement: step 8, image 1 of 1
    • Close up the mouse, and replace the three 9 mm using a Phillips #1 screwdriver.
  9. Razer Deathadder Essential RZ01-0254 Mouse Buttons Replacement: step 9, image 1 of 1
    • Finally, replace the skates and you are finished.
Finish Line
6 other people completed this guide.
JMason
349 Reputation
1 Guide authored
4 Guide Comments
you helped me a lot
Gustavo Melo Santos - Reply
My scroll wheel was totally messed up, when I would scroll in down, it would randomly scroll up for for a split second, and vice versa. This guide was super helpful in figuring out how to take apart the mouse and clean out the scroll wheel sensor, which turned out to have a ton of cat hair wrapped around the axle.
Chris Etler - Reply
My mouse is not working when i plug it in the pc what is the problem ?
Kros Sss - Reply
Thank you for the help! Had a Sharkoon Fireglider mouse and apart from a few other different placement designs was able to replace the left click button component. Much appreciated!
Yashin lalji - Reply
Past 24 Hours: 7
Past 7 Days: 86
Past 30 Days: 306
All Time: 12,077
