Razer Deathadder Essential RZ01-0254 Mouse Buttons Replacement
  1. Razer Deathadder Essential RZ01-0254 Mouse Buttons Replacement, Mouse Buttons: step 1, image 1 of 2 Razer Deathadder Essential RZ01-0254 Mouse Buttons Replacement, Mouse Buttons: step 1, image 2 of 2
    • Use a spudger or opening tool to remove the top skates from the mouse.
    • Poke a hole in the middle of the bar code to expose the 3 screws holding the mouse together.
  2. Razer Deathadder Essential RZ01-0254 Mouse Buttons Replacement: step 2, image 1 of 1
    • Use a Phillips #1 screwdriver to remove the three 9 mm screws that are holding the mouse together.
  3. Razer Deathadder Essential RZ01-0254 Mouse Buttons Replacement: step 3, image 1 of 3 Razer Deathadder Essential RZ01-0254 Mouse Buttons Replacement: step 3, image 2 of 3 Razer Deathadder Essential RZ01-0254 Mouse Buttons Replacement: step 3, image 3 of 3
    • Open the mouse, and use the Phillips #1 screwdriver remove the two 11 mm screws that are located on the left side of the motherboard.
    • Also, remove the single 4 mm screw next to the mouse wheel using the Phillips #1 screwdriver.
    • After you remove all three screws the motherboard should be free.
  4. Razer Deathadder Essential RZ01-0254 Mouse Buttons Replacement: step 4, image 1 of 2 Razer Deathadder Essential RZ01-0254 Mouse Buttons Replacement: step 4, image 2 of 2
    • This is the component that we will be replacing and its 3 contact points.
  5. Razer Deathadder Essential RZ01-0254 Mouse Buttons Replacement: step 5, image 1 of 1
    Tool used on this step:
    Desoldering Pump
    $3.99
    Buy
    • Using your soldering iron and desoldering pump, desolder the 3 contact points that attach to each button as marked.
    • Be careful when using a soldering iron, as it can burn you if not used correctly.
  6. Razer Deathadder Essential RZ01-0254 Mouse Buttons Replacement: step 6, image 1 of 3 Razer Deathadder Essential RZ01-0254 Mouse Buttons Replacement: step 6, image 2 of 3 Razer Deathadder Essential RZ01-0254 Mouse Buttons Replacement: step 6, image 3 of 3
    • Remove the button that you just desoldered.
    • Then solder the new button back into place. Repeat for both buttons.
  7. Razer Deathadder Essential RZ01-0254 Mouse Buttons Replacement: step 7, image 1 of 3 Razer Deathadder Essential RZ01-0254 Mouse Buttons Replacement: step 7, image 2 of 3 Razer Deathadder Essential RZ01-0254 Mouse Buttons Replacement: step 7, image 3 of 3
    • Return the motherboard to its original position, and replace the two 11 mm screws and the single 4 mm screw using a Phillips #1 screwdriver.
  8. Razer Deathadder Essential RZ01-0254 Mouse Buttons Replacement: step 8, image 1 of 1
    • Close up the mouse, and replace the three 9 mm using a Phillips #1 screwdriver.
  9. Razer Deathadder Essential RZ01-0254 Mouse Buttons Replacement: step 9, image 1 of 1
    • Finally, replace the skates and you are finished.
Finish Line
5 other people completed this guide.
JMason
313 Reputation
1 Guide authored
One Comment
you helped me a lot
Gustavo Melo Santos - Reply
Past 24 Hours: 9
Past 7 Days: 81
Past 30 Days: 320
All Time: 6,730
