Razer DeathAdder V3 Pro Optical Switch Replacement
    1. Razer DeathAdder V3 Pro Optical Switch Replacement, Scroll Wheel: step 1, image 1 of 3 Razer DeathAdder V3 Pro Optical Switch Replacement, Scroll Wheel: step 1, image 2 of 3 Razer DeathAdder V3 Pro Optical Switch Replacement, Scroll Wheel: step 1, image 3 of 3
      • Use a pry tool or fingernail to carefully remove the large foot on the lower end of the mouse.
      • Remove the three 7 mm screws using a Torx T6 screwdriver.
      Ask FixBot
    2. Razer DeathAdder V3 Pro Optical Switch Replacement: step 2, image 1 of 2 Razer DeathAdder V3 Pro Optical Switch Replacement: step 2, image 2 of 2
      • BEFORE YOU OPEN THE MOUSE: Be careful at this point. Both shells are connected with a cable in the front of the mouse.
      • Insert a spudger into the seam between the top and bottom shells.
      • Gently work around the edges unclipping the internal latches.
      • Slowly lift the top shell but do not remove it yet; the cables are still attached to the circuit board.
      • Carefully pull the shells apart to unplug the cable in the front.
      Ask FixBot
    3. Razer DeathAdder V3 Pro Optical Switch Replacement: step 3, image 1 of 2 Razer DeathAdder V3 Pro Optical Switch Replacement: step 3, image 2 of 2
      • Using a small pry tool or your fingers, gently pop the scroll wheel up and out of its housing
      Ask FixBot
    1. Razer DeathAdder V3 Pro Optical Switch Replacement, Optical Switch: step 4, image 1 of 1
      • Use a T6 Torx screwdriver to remove the 5mm screws from the circuit board.
      • Unplug the battery from its connection on the right.
      • Be careful not to break the two clips that hold the PCB at the front of the mouse.
      • Remove the circuit board from the mouse.
      Ask FixBot
    2. Razer DeathAdder V3 Pro Optical Switch Replacement: step 5, image 1 of 1
      • Remove the faulty optical switches on the right and left corners of the PCB using your fingers.
      • Insert a new switch where needed.
      Ask FixBot
Nicholas
453 Reputation
4 Guides authored
Texas Tech, Team 2-5, Johansen Fall 2025 Member of Texas Tech, Team 2-5, Johansen Fall 2025
TTU-JOHANSEN-F25S2G5
5 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 8
Past 7 Days: 40
Past 30 Days: 164
All Time: 1,274
