Razer DeathAdder V3 Pro Macro Buttons Replacement
    1. Razer DeathAdder V3 Pro Macro Buttons Replacement, Scroll Wheel: step 1, image 1 of 3 Razer DeathAdder V3 Pro Macro Buttons Replacement, Scroll Wheel: step 1, image 2 of 3 Razer DeathAdder V3 Pro Macro Buttons Replacement, Scroll Wheel: step 1, image 3 of 3
      • Use a pry tool or fingernail to carefully remove the large foot on the lower end of the mouse.
      • Remove the three 7 mm screws using a Torx T6 screwdriver.
      Ask FixBot
    2. Razer DeathAdder V3 Pro Macro Buttons Replacement: step 2, image 1 of 2 Razer DeathAdder V3 Pro Macro Buttons Replacement: step 2, image 2 of 2
      • BEFORE YOU OPEN THE MOUSE: Be careful at this point. Both shells are connected with a cable in the front of the mouse.
      • Insert a spudger into the seam between the top and bottom shells.
      • Gently work around the edges unclipping the internal latches.
      • Slowly lift the top shell but do not remove it yet; the cables are still attached to the circuit board.
      • Carefully pull the shells apart to unplug the cable in the front.
      Ask FixBot
    3. Razer DeathAdder V3 Pro Macro Buttons Replacement: step 3, image 1 of 2 Razer DeathAdder V3 Pro Macro Buttons Replacement: step 3, image 2 of 2
      • Using a small pry tool or your fingers, gently pop the scroll wheel up and out of its housing
      Ask FixBot
    1. Razer DeathAdder V3 Pro Macro Buttons Replacement, Macro Buttons: step 4, image 1 of 1
      • Unplug the ribbon cable connected to the side macro buttons from its raised position on the left.
      • Remove the macro buttons.
      Ask FixBot
    2. Razer DeathAdder V3 Pro Macro Buttons Replacement: step 5, image 1 of 2 Razer DeathAdder V3 Pro Macro Buttons Replacement: step 5, image 2 of 2
      • Use a spudger to remove the solder covering the switch, then pop off the faulty switch.
      • Apply flux, then use a soldering iron to heat the old solder.
      • Make sure to solder in a well-ventilated area.
      • Clean off the melted solder.
      Ask FixBot
    3. Razer DeathAdder V3 Pro Macro Buttons Replacement: step 6, image 1 of 1
      • Apply flux to the removal sites of the switches.
      • Solder the new switches into the areas where the original switches were removed.
      Ask FixBot
Matthew Garcia
197 Reputation
1 Guide authored
Texas Tech, Team 2-5, Johansen Fall 2025 Member of Texas Tech, Team 2-5, Johansen Fall 2025
TTU-JOHANSEN-F25S2G5
5 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 32
Past 30 Days: 133
All Time: 703
