Razer DeathAdder V3 Pro Encoder Replacement
Views: 2.7K
View statistics:
Past 24 Hours:
28
Past 7 Days:
128
Past 30 Days:
495
All Time:
2,657
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 15 - 30 minutes
Difficulty: Moderate
Better Introduction
Improve this guide by completing or revising its introduction.
Introduction
Go to step 1 ↓
If your Razer DeathAdder V3 Pro's Scroll Wheel is unresponsive to input, jumping, or responds incorrectly, you may need to replace the Scroll Wheel Encoder.
For any quick fixes, please visit our troubleshooting guides for the Razer DeathAdder V3 Pro Scroll Wheel Not Responding to Input and Razer DeathAdder V3 Pro Spotty Wired Connection. If these fixes do not resolve your issues, please follow this guide to replace your scroll wheel.
Before you begin the replacement, please make sure that you have unplugged and powered off the device.
Tools
    1. Razer DeathAdder V3 Pro Encoder Replacement, Scroll Wheel: step 1, image 1 of 3 Razer DeathAdder V3 Pro Encoder Replacement, Scroll Wheel: step 1, image 2 of 3 Razer DeathAdder V3 Pro Encoder Replacement, Scroll Wheel: step 1, image 3 of 3
      • Use a pry tool or fingernail to carefully remove the large foot on the lower end of the mouse.
      • Remove the three 7 mm screws using a Torx T6 screwdriver.
      Ask FixBot
    2. Razer DeathAdder V3 Pro Encoder Replacement: step 2, image 1 of 2 Razer DeathAdder V3 Pro Encoder Replacement: step 2, image 2 of 2
      • BEFORE YOU OPEN THE MOUSE: Be careful at this point. Both shells are connected with a cable in the front of the mouse.
      • Insert a spudger into the seam between the top and bottom shells.
      • Gently work around the edges unclipping the internal latches.
      • Slowly lift the top shell but do not remove it yet; the cables are still attached to the circuit board.
      • Carefully pull the shells apart to unplug the cable in the front.
      Ask FixBot
    3. Razer DeathAdder V3 Pro Encoder Replacement: step 3, image 1 of 2 Razer DeathAdder V3 Pro Encoder Replacement: step 3, image 2 of 2
      • Using a small pry tool or your fingers, gently pop the scroll wheel up and out of its housing
      Ask FixBot
    1. Razer DeathAdder V3 Pro Encoder Replacement, Encoder: step 4, image 1 of 1
      • Use a T6 Torx screwdriver to remove the 5mm screws securing the circuit board.
      • Unplug the battery from its connection on the right side.
      • Be careful not to break the two clips that hold the PCB at the front of the mouse.
      Ask FixBot
    2. Razer DeathAdder V3 Pro Encoder Replacement: step 5, image 1 of 1
      • At the front of the PCB next to the encoder, remove the switch held in place by clips by gently pulling it free.
      Ask FixBot
    3. Razer DeathAdder V3 Pro Encoder Replacement: step 6, image 1 of 2 Razer DeathAdder V3 Pro Encoder Replacement: step 6, image 2 of 2
      • Wear eye protection.
      • Take care not to damage the PCB or any other components.
      • Use a pair of flush cutters to cut the legs of the encoder.
      • Desolder the legs of the 15 mm encoder on the underside of the PCB.
      • Remove the encoder.
      • Always solder in a well ventilated area.
      • Use a solder sucker to remove any excess solder.
      Ask FixBot
    4. Razer DeathAdder V3 Pro Encoder Replacement: step 7, image 1 of 1
      • Press the new 15 mm encoder into place
      • If the encoder does not fit properly, clean the old solder more thoroughly.
      • Solder the new 15 mm encoder into place.
      Ask FixBot
Nicholas
453 Reputation
4 Guides authored
Texas Tech, Team 2-5, Johansen Fall 2025 Member of Texas Tech, Team 2-5, Johansen Fall 2025
TTU-JOHANSEN-F25S2G5
5 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 28
Past 7 Days: 128
Past 30 Days: 495
All Time: 2,657
