Introduction
I Intend to show you how to safely remove the battery.
Flip the hold down up
Remove the cable
Repeat for second cable
Use a spudger to disconnect the plug from the connector by pulling it away from the socket, parallel to the board.
Bend the connector backwards to prevent it from getting in the way of the motherboard.
Remove the 7 battery screws
does anyone know where I can buy that white cable? Mine broke on swollen battery, THANKS!
Remove the battery by pulling up from the side closest to the motherboard
21 other people completed this guide.
17 Comments
i want buy a battery for razer blade but I can't buy it anywhere
Please help me, my battery only 20% heathly
It seems that the only way to get the battery replaced is to send the laptop to Razer directly. According to others it costs about $200 plus shipping and so on. Unless you find something on eBay or that sort of thing.
tallme15 -
May I have a detailed guide on how you remove the cable over the battery, please? I am not used to taking machines apart, and wouldn't want to risk ruining my laptop. (didn't quite understand your pictures)
The only way to remove the cable is to work it out with a set of tweezers and be gentle not to pull the cables lose from the connector.
Thank you for these instructions, it was very helpful, the only problem is now that the new battery has been installed, it will only charge to 73% and while its still plugged in the battery will drain down to 0%, is there a fix for this problem?
This is likely an issue with the new battery you got. The only suggestion that I could give you is to check the battery connections. If your old battery held even a bit of charge for a while its would be a pretty good indication that you have a dud. Although if the old battery acted similarly it could be possible that there is a fault in the laptops battery controller circuit.
tallme15 -
Is it posible to use the laptop without the battery ? Mine is swollen and just holds up 1 min of charge. I´m not living now on a country covered by razer RMA.
Yes you can. I am running without the battery right now, just for testing purposes.
Thank you! Only took me roughly 40 minutes with no prior experience whatsoever. My Razer Blade is running brand new and no longer needs to be plugged in all the time to actually work.
Where did you get a new battery ?
Are there any differences to be aware of with the Razer Blade 14 2015 model? Also, is it the same battery for the 2015 as the 2013?
I just did this on my Razer Blade 2014 (also disconnected the motherboard and replaced my keyboard), and everything was exactly the same. Assuming these instructions will remain the same for several years’ worth of versions.
where would you purchase a new battery? I would rather do it myself then spend alot of money in shipping, and labor as well as being without my laptop for awhile.
I purchased my genuine replacement battery on eBay, as Razer no longer carries them/supports older models like my Blade 2014.
Can I add more RAM to this laptop? I have the 8gb model
I broke the touchpad cable. Where can i buy a new one?
