Razer Basilisk V3 Switch Replacement
    1. Razer Basilisk V3 Switch Replacement, Skates: step 1, image 1 of 1
      • Locate the highlighted white skates on the bottom of the mouse.
      Ask FixBot
    2. Razer Basilisk V3 Switch Replacement: step 2, image 1 of 3 Razer Basilisk V3 Switch Replacement: step 2, image 2 of 3 Razer Basilisk V3 Switch Replacement: step 2, image 3 of 3
      • Heat the skate using a heat gun or hair dryer.
      • Using the pointy end of the spudger pry away a corner of the skate.
      • If the adhesive does not pull away easily, heat the skate more.
      • Once the corner of the skate comes free use the flat end of the spudger to peel off the rest of the skate.
      • Repeat these steps for each of the skates.
      Ask FixBot
    1. Razer Basilisk V3 Switch Replacement, Backplate: step 3, image 1 of 1
      • Remove two 4.8 mm screws that were hidden under the front skates using a JIS #1 screwdriver.
      • Remove the single 4 mm screw beneath the thumb grip using a JIS #1 screwdriver.
      Ask FixBot
    2. Razer Basilisk V3 Switch Replacement: step 4, image 1 of 3 Razer Basilisk V3 Switch Replacement: step 4, image 2 of 3 Razer Basilisk V3 Switch Replacement: step 4, image 3 of 3
      • Heat the label gently with a heat gun or hair dryer.
      • Once the adhesive is loosened, use a spudger to peel off the label carefully, revealing two additional screws.
      • Remove the two 4.8 mm screws using a JIS #1 screwdriver.
      Ask FixBot
    3. Razer Basilisk V3 Switch Replacement: step 5, image 1 of 3 Razer Basilisk V3 Switch Replacement: step 5, image 2 of 3 Razer Basilisk V3 Switch Replacement: step 5, image 3 of 3
      • Carefully pry apart the mouse's top and bottom halves. Using the iFixit opening tool, start at one corner and work around the edge.
      • Be cautious of the clips that may break during this process.
      • Using a plastic opening tool, gently pry the connector apart by moving side to side to avoid bending the pins.
      • When reassembling, be mindful that the connector only fits one way, as shown in the pictures.
      Ask FixBot
    1. Razer Basilisk V3 Switch Replacement, Scroll Wheel Assembly: step 6, image 1 of 3 Razer Basilisk V3 Switch Replacement, Scroll Wheel Assembly: step 6, image 2 of 3 Razer Basilisk V3 Switch Replacement, Scroll Wheel Assembly: step 6, image 3 of 3
      • Use the flat end of the spudger to pop-out the scroll wheel assembly.
      • Make sure you are careful when removing the scroll wheel since it is still connected to the device with a ribbon cable. If you pull too hard the cable could break.
      Ask FixBot
    2. Razer Basilisk V3 Switch Replacement: step 7, image 1 of 3 Razer Basilisk V3 Switch Replacement: step 7, image 2 of 3 Razer Basilisk V3 Switch Replacement: step 7, image 3 of 3
      • Pull up on the top half of the cable connector and pull the cable from the connector.
      • The connection pins on the wire face towards the scroll wheel assembly housing. When reassembling, make sure the connectors on the cable are facing the correct direction.
      Ask FixBot
    1. Razer Basilisk V3 Switch Replacement, Switch: step 8, image 1 of 1
      • Use the flat end of the spudger to press the two main button modules out from their mountings.
      • Apply steady pressure to just the button modules to avoid damaging the surrounding plastic.
      Ask FixBot
[deleted]
402 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 10
Past 7 Days: 80
Past 30 Days: 292
All Time: 5,201
