Introduction
The side brushes are a problem many people encounter when dealing with the RYDIS H68 Pro. This guide will show you how to fix a side brush issue.
Flip the vacuum over so that the wheels are facing you.
Use a Phillips #1 screwdriver to remove the four 10 mm screws that surround the battery cover.
Begin by unscrewing the 2 10mm screws using a Phillips #1 screwdriver.
Unlatch the latches indicated. It can be easily done with your finger.
Once unsecured, the covering for the sensors can easily be removed allowing access to the sensors.
