Shop the Holiday Gift Guide
REL T5 Repaste transistors
View statistics:
Past 24 Hours:
2
Past 7 Days:
29
Past 30 Days:
86
All Time:
234
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Community-Contributed Guide
    1. REL T5 Repaste transistors, Repaste heatsink and pads: step 1, image 1 of 3 REL T5 Repaste transistors, Repaste heatsink and pads: step 1, image 2 of 3 REL T5 Repaste transistors, Repaste heatsink and pads: step 1, image 3 of 3
      • Re-apply thermal grease. Make sure to use an appropriate type. Hint: CPU paste is usually not the best solution.
      • Apply a little dot on the pad and place on the heatsink.
      • After speading it with a spatula, stick two together, and slide to distribute evenly.
      • Careful as to not damage the pads!
      Ask FixBot
    2. REL T5 Repaste transistors: step 2, image 1 of 2 REL T5 Repaste transistors: step 2, image 2 of 2
      • Apply a thin layer using the spatula on the transistors as well.
      • Mount the amplifier board back on its place.
      • Carefully set the transistors using the screws.
      • Fix the power board using its screws.
      • Check that there are no shorts between the transistors and the heatsink or backplate.
      Ask FixBot
Jasper van Zuijlen
1,200 Reputation
15 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 29
Past 30 Days: 86
All Time: 234
