RCA RCT6378W2 Battery Replacement
  1. RCA RCT6378W2 Battery Replacement, Battery: step 1, image 1 of 3 RCA RCT6378W2 Battery Replacement, Battery: step 1, image 2 of 3 RCA RCT6378W2 Battery Replacement, Battery: step 1, image 3 of 3
    • Remove the two 2.4 mm x 4 mm Phillips #00 screws from the bottom of the tablet.
  2. RCA RCT6378W2 Battery Replacement: step 2, image 1 of 3 RCA RCT6378W2 Battery Replacement: step 2, image 2 of 3 RCA RCT6378W2 Battery Replacement: step 2, image 3 of 3
    • Remove the back cover with a plastic opening tool, exposing the battery and motherboard.
  3. RCA RCT6378W2 Battery Replacement: step 3, image 1 of 3 RCA RCT6378W2 Battery Replacement: step 3, image 2 of 3 RCA RCT6378W2 Battery Replacement: step 3, image 3 of 3
    • Remove the two black tape strips from the battery pack.
  4. RCA RCT6378W2 Battery Replacement: step 4, image 1 of 3 RCA RCT6378W2 Battery Replacement: step 4, image 2 of 3 RCA RCT6378W2 Battery Replacement: step 4, image 3 of 3
    • Remove the battery pack by carefully prying the battery back from the front cover. Then, remove the wires connecting the battery to the motherboard at the motherboard using the tweezers.
  5. RCA RCT6378W2 Battery Replacement: step 5, image 1 of 1
    • Replace the damaged or malfunctioning battery with the new battery and wires. The new battery must be stuck back into its original place using thermal tape.
  6. RCA RCT6378W2 Battery Replacement: step 6, image 1 of 3 RCA RCT6378W2 Battery Replacement: step 6, image 2 of 3 RCA RCT6378W2 Battery Replacement: step 6, image 3 of 3
    • The new wires must be soldered back into place on the motherboard at the original location.
    • For tips on soldering techniques, see this Soldering Guide.
Justin
425 Reputation
2 Guides authored
Clemson, Team 14-4, Shirley Spring 2015 Member of Clemson, Team 14-4, Shirley Spring 2015
CLEM-SHIRLEY-S15S14G4
6 Members
15 Guides authored
Past 24 Hours: 5
Past 7 Days: 14
Past 30 Days: 50
All Time: 26,969
