RAVPower FileHub Travel Router AC750 Disassembly
    1. RAVPower FileHub Travel Router AC750 Disassembly, Bring your device and make sure everything is off and disconnected: step 1, image 1 of 2 RAVPower FileHub Travel Router AC750 Disassembly, Bring your device and make sure everything is off and disconnected: step 1, image 2 of 2
      • Brand New RAVPower FileHub Travel Router AC750
      • No screws what so ever, all is tightly sealed.
      Ask FixBot
    2. RAVPower FileHub Travel Router AC750 Disassembly, Open the rubber seal and shimmy on the case surrounding the connectors: step 2, image 1 of 3 RAVPower FileHub Travel Router AC750 Disassembly, Open the rubber seal and shimmy on the case surrounding the connectors: step 2, image 2 of 3 RAVPower FileHub Travel Router AC750 Disassembly, Open the rubber seal and shimmy on the case surrounding the connectors: step 2, image 3 of 3
      • Open the rubber seal and begin, very carefully, opening the surroundings.
      • 'Note that there is an adhesive on the other side holding the case' among other elements like: battery (most prominent), the WiFi antennas (is the 2.4Ghz & 5Ghz on the top of the case) and the lights circuit of the device.
      Ask FixBot
    3. RAVPower FileHub Travel Router AC750 Disassembly, Pull the case a bit, be careful not to break the top parts: step 3, image 1 of 3 RAVPower FileHub Travel Router AC750 Disassembly, Pull the case a bit, be careful not to break the top parts: step 3, image 2 of 3 RAVPower FileHub Travel Router AC750 Disassembly, Pull the case a bit, be careful not to break the top parts: step 3, image 3 of 3
      • Again, open carefully because of the attached items to the top case. In this picture a accidentally broke the connection in the 5Ghz WiFi Antenna.
      Ask FixBot
    4. RAVPower FileHub Travel Router AC750 Disassembly, It's open! congrats!: step 4, image 1 of 3 RAVPower FileHub Travel Router AC750 Disassembly, It's open! congrats!: step 4, image 2 of 3 RAVPower FileHub Travel Router AC750 Disassembly, It's open! congrats!: step 4, image 3 of 3
      • Insert wisdom here.
      Ask FixBot
Andres Urena
139 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 17
Past 30 Days: 41
All Time: 1,586
