Replace or expand RAM memory
Archived Guide
This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
  1. Replace or expand RAM memory, Battery: step 1, image 1 of 3 Replace or expand RAM memory, Battery: step 1, image 2 of 3 Replace or expand RAM memory, Battery: step 1, image 3 of 3
    • Open the latch on the right side that secures the battery in place.
    • Open the latch on the left side that secures the battery in place.
    • Now remove the battery.
  2. Replace or expand RAM memory, Main access cover: step 2, image 1 of 3 Replace or expand RAM memory, Main access cover: step 2, image 2 of 3 Replace or expand RAM memory, Main access cover: step 2, image 3 of 3
    • Using a Philips-head screwdriver remove highlighted screws.
    • Look at the marking to see how to remove the access cover.
    • Remove the access cover as shown by the marker.
  3. Replace or expand RAM memory: step 3, image 1 of 1
    • You now have access to all components of this laptop.
  4. Replace or expand RAM memory, RAM memory: step 4, image 1 of 3 Replace or expand RAM memory, RAM memory: step 4, image 2 of 3 Replace or expand RAM memory, RAM memory: step 4, image 3 of 3
    • Here is the default installed memory module.
    • Locate and squeeze the tension springs that secure the memory module apart.
    • Pull the memory module (RAM) out of its plug.
  5. Replace or expand RAM memory: step 5, image 1 of 1
    • This is what the remote memory module looks like.
To assemble the device again, proceed in reverse order.
Special thanks to these translators:
de en
100%
irlanda is helping us fix the world! Want to contribute?
Start translating ›
Felice Suglia
31,100 Reputation
264 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 5
All Time: 144
