Repair of a collector PS4 controller MGSV JDM-030
  1. Repair of a collector PS4 controller MGSV JDM-030, conductive film flexible cable: step 1, image 1 of 3 Repair of a collector PS4 controller MGSV JDM-030, conductive film flexible cable: step 1, image 2 of 3 Repair of a collector PS4 controller MGSV JDM-030, conductive film flexible cable: step 1, image 3 of 3
    • Here is the controller to troubleshoot.
    • The controller is made of 2 large plastic parts. To detach them, press the lever as shown in the photo. A gap should form, allowing you to insert an item (like the iFixit Opening Picks).
  2. Repair of a collector PS4 controller MGSV JDM-030: step 2, image 1 of 1
    • Open the controller, taking care not to detach the R2 and L2 triggers. Otherwise, be careful not to lose the springs of these triggers.
    • Déconnecter la batterie en tirant légèrement sur le connecteur blanc relié à la face avant de la manette.
    • Déconnecter le fil électrique qui relie les 2 partie de la manette entre-elles en prenant soin de ne tirer que sur la languette au bout.
  3. Repair of a collector PS4 controller MGSV JDM-030: step 3, image 1 of 3 Repair of a collector PS4 controller MGSV JDM-030: step 3, image 2 of 3 Repair of a collector PS4 controller MGSV JDM-030: step 3, image 3 of 3
    • The support that holds the battery must be removed by unscrewing the Phillips screw.
  4. Repair of a collector PS4 controller MGSV JDM-030: step 4, image 1 of 3 Repair of a collector PS4 controller MGSV JDM-030: step 4, image 2 of 3 Repair of a collector PS4 controller MGSV JDM-030: step 4, image 3 of 3
    • Identify connectors in poor condition and clean them with alcohol.
  5. Repair of a collector PS4 controller MGSV JDM-030: step 5, image 1 of 3 Repair of a collector PS4 controller MGSV JDM-030: step 5, image 2 of 3 Repair of a collector PS4 controller MGSV JDM-030: step 5, image 3 of 3
    • The key pads can then be removed and replaced with new ones.
    • All that remains is to put everything back together.
To reassemble your device, follow the instructions in reverse order.
Special thanks to these translators:
fr en
100%
HelloMacOS is helping us fix the world! Want to contribute?
Start translating ›
David Jouvin
85 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 40
All Time: 1,544
