Putting On A Transparent Shell On Flipper Zero
    1. Putting On A Transparent Shell On Flipper Zero, Take Out The SD Card: step 1, image 1 of 1
      • An Easy Way To Get The SD Card Out Is To Grip It With Your Fingernails.
      Ask FixBot
    2. Putting On A Transparent Shell On Flipper Zero, Remove The 4 PH0 Screws On The Back: step 2, image 1 of 3 Putting On A Transparent Shell On Flipper Zero, Remove The 4 PH0 Screws On The Back: step 2, image 2 of 3 Putting On A Transparent Shell On Flipper Zero, Remove The 4 PH0 Screws On The Back: step 2, image 3 of 3
      • Use A PH0 Screwdriver To Open/Remove The Back Part Of The Shell.
      • Be Careful, The Screws Strip Easily. One Way To Combat This Is To Press Down On The Screw While Unscrewing It.
      Ask FixBot
    3. Putting On A Transparent Shell On Flipper Zero, Taking Off The Back Shell: step 3, image 1 of 3 Putting On A Transparent Shell On Flipper Zero, Taking Off The Back Shell: step 3, image 2 of 3 Putting On A Transparent Shell On Flipper Zero, Taking Off The Back Shell: step 3, image 3 of 3
      • Using Your Fingernail, Spudger, Guitar Pick, Or Any Other Prying Tool, Take Off The Back Shell.
      Ask FixBot
    4. Putting On A Transparent Shell On Flipper Zero, Take Out The Internals: step 4, image 1 of 3 Putting On A Transparent Shell On Flipper Zero, Take Out The Internals: step 4, image 2 of 3 Putting On A Transparent Shell On Flipper Zero, Take Out The Internals: step 4, image 3 of 3
      • Using Your PH0 Screwdriver Unscrew The Two Short Screws Holding The Internals Down To The Shell.
      • Be Careful With The iButton Pins, They Break Off Very Easily.
      Ask FixBot
    5. Putting On A Transparent Shell On Flipper Zero, Transfer The Flipper's Internals To The New Shell: step 5, image 1 of 2 Putting On A Transparent Shell On Flipper Zero, Transfer The Flipper's Internals To The New Shell: step 5, image 2 of 2
      • Put Your Flipper's Internals Into The New Shell.
      • Screw The Three Short Screws Back Into Place.
      • Do Not Make The Screws Too Tight As The Threads On The New Transparent Board Will Strip Because It Is 3D Printed.
      Ask FixBot
    6. Putting On A Transparent Shell On Flipper Zero, Take The NFC Board Off The Back Shell: step 6, image 1 of 2 Putting On A Transparent Shell On Flipper Zero, Take The NFC Board Off The Back Shell: step 6, image 2 of 2
      • Using Your, Spudger, Guitar Pick, Flathead Screwdriver, Or Any Other Prying Tool, Take Off The NFC Board. Heating may help if it sticks too much.
      • Do Not Use Your Fingernails To Take Off The NFC Board!
      Ask FixBot
    7. Putting On A Transparent Shell On Flipper Zero, Put The NFC Board Onto The New Transparent Back Shell: step 7, image 1 of 1
      • The NFC Board Should Look Like How It Is In The Picture, If It Doesn't Look Like The Picture Reapply The NFC Board.
      Ask FixBot
    8. Putting On A Transparent Shell On Flipper Zero, Combine The Two Shells: step 8, image 1 of 2 Putting On A Transparent Shell On Flipper Zero, Combine The Two Shells: step 8, image 2 of 2
      • Put The Two Shells Together And Then Insert The Four Long Screws Into The Screw Holes And Tighten Them.
      Ask FixBot
    9. Putting On A Transparent Shell On Flipper Zero, YA DONE!: step 9, image 1 of 2 Putting On A Transparent Shell On Flipper Zero, YA DONE!: step 9, image 2 of 2
      • You Have Just Assembled Yourself A Transparent Flipper Zero, Nice Work!
      Ask FixBot
Finish Line
5 other people completed this guide.
Kaeden
403 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 10
Past 7 Days: 61
Past 30 Days: 296
All Time: 3,506
