Puritan Bennett 540 Alarm Resetting Technique
Medical Equipment
Neither iFixit nor this repair guide is endorsed by or affiliated with the medical device manufacturer.
  1. Puritan Bennett 540 Alarm Resetting Technique, Puritan Bennett 540 Alarm Resetting Technique: step 1, image 1 of 1
    • Press the MENU Key to access the Alarm Settings Menu.
  2. Puritan Bennett 540 Alarm Resetting Technique: step 2, image 1 of 2 Puritan Bennett 540 Alarm Resetting Technique: step 2, image 2 of 2
    • Press the down arrow key to position the cursor on the “Alarm Logs” line, if this is not already the case.
  3. Puritan Bennett 540 Alarm Resetting Technique: step 3, image 1 of 1
    • Press the Enter key to confirm the selection of the Alarm Menu.
  4. Puritan Bennett 540 Alarm Resetting Technique: step 4, image 1 of 2 Puritan Bennett 540 Alarm Resetting Technique: step 4, image 2 of 2
    • Press the up arrow key to position the cursor on the “Reactivate Paused Alarm” line. The following graphic shows the resulting display.
  5. Puritan Bennett 540 Alarm Resetting Technique: step 5, image 1 of 3 Puritan Bennett 540 Alarm Resetting Technique: step 5, image 2 of 3 Puritan Bennett 540 Alarm Resetting Technique: step 5, image 3 of 3
    • Press the Enter key for at least three (3) seconds. The following events occur:
    • A “beep” sounds.
    • An audible alarm sounds.
    • An alarm indicator illuminates.
    • The messages of all active alarms are displayed in a loop in the Ventilation and Alarm menus.
    • The Audio Paused symbol disappears (if it was displayed).
    • The Alarm Paused symbol disappears.
There is no need to reassemble the device, but if the condition persists you can try resetting the audio again.
kerribyrne
267 Reputation
2 Guides authored
Cal Poly, Team S7-G7, Paton Spring 2020 Member of Cal Poly, Team S7-G7, Paton Spring 2020
CPSU-PATON-S20S7G7
3 Members
3 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 113
