Purewell Gravity Water Filter Replacement
    1. Purewell Gravity Water Filter Replacement, Water Filter: step 1, image 1 of 3 Purewell Gravity Water Filter Replacement, Water Filter: step 1, image 2 of 3 Purewell Gravity Water Filter Replacement, Water Filter: step 1, image 3 of 3
      • Remove the lid of the water system.
      • Lift the top half of the water system to remove it.
      Ask FixBot
    2. Purewell Gravity Water Filter Replacement: step 2, image 1 of 2 Purewell Gravity Water Filter Replacement: step 2, image 2 of 2
      • Place the top half near a sink.
      • Turn it over so you can reach the wingnuts and washers underneath.
      Ask FixBot
    3. Purewell Gravity Water Filter Replacement: step 3, image 1 of 3 Purewell Gravity Water Filter Replacement: step 3, image 2 of 3 Purewell Gravity Water Filter Replacement: step 3, image 3 of 3
      • Rotate each wingnut counter-clockwise to loosen the filter.
      Ask FixBot
    4. Purewell Gravity Water Filter Replacement: step 4, image 1 of 2 Purewell Gravity Water Filter Replacement: step 4, image 2 of 2
      • Flip it over so the top is accessible.
      • Remove the wingnuts and washers from the bottom of the top section.
      • Remove the filter out of the system.
      • Remove the washer from the filter.
      Ask FixBot
    5. Purewell Gravity Water Filter Replacement: step 5, image 1 of 2 Purewell Gravity Water Filter Replacement: step 5, image 2 of 2
      • Place the primer button on to the filter.
      • Ensure the primer button is aligned with the filter attachment.
      Ask FixBot
    6. Purewell Gravity Water Filter Replacement: step 6, image 1 of 3 Purewell Gravity Water Filter Replacement: step 6, image 2 of 3 Purewell Gravity Water Filter Replacement: step 6, image 3 of 3
      • Turn the sink on low so the water runs slowly.
      • Press the end of the filter with the primer button firmly against the faucet to ensure water flows only into the filter.
      • Wait for the filter to start sweating to remove the filter away from the sink.
      Ask FixBot
    7. Purewell Gravity Water Filter Replacement: step 7, image 1 of 3 Purewell Gravity Water Filter Replacement: step 7, image 2 of 3 Purewell Gravity Water Filter Replacement: step 7, image 3 of 3
      • Remove the primer button and place the washer back on the filter.
      • Place the filter through the hole in the bottom of the top section of the system.
      Ask FixBot
    8. Purewell Gravity Water Filter Replacement: step 8, image 1 of 3 Purewell Gravity Water Filter Replacement: step 8, image 2 of 3 Purewell Gravity Water Filter Replacement: step 8, image 3 of 3
      • Flip it over so the bottom is facing up.
      • Make sure the filter to hold the filter so it doesn't drop out.
      • Rotate the washer clockwise and tighten the wingnut until it is securely attached.
      • Avoid overtightening the wingnut and washer, as this can make it difficult to replace the filter next time.
      Ask FixBot
    9. Purewell Gravity Water Filter Replacement: step 9, image 1 of 2 Purewell Gravity Water Filter Replacement: step 9, image 2 of 2
      • Place the top half back onto the system and replace the lid.
      Ask FixBot
Finish Line
Alex Lam
169 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 38
Past 30 Days: 158
All Time: 1,879
