Prusa i3 Mk2 Nozzle Replacement
    1. Prusa i3 Mk2  Nozzle Replacement, Nozzle: step 1, image 1 of 3 Prusa i3 Mk2  Nozzle Replacement, Nozzle: step 1, image 2 of 3 Prusa i3 Mk2  Nozzle Replacement, Nozzle: step 1, image 3 of 3
      Tool used on this step:
      Buy
      • Turn the 3D printer on using the power switch.
      • Move the head to the highest position on the Z axis. This provides working room to access the head.
      • Heat the nozzle up. This step depends on what type of filament is currently in the machine (e.g. 190 for PLA, 220 for ABS).
      • Remove filament from the 3D printer.
      • Clean off the old nozzle with tweezers.
      Ask FixBot
    2. Prusa i3 Mk2  Nozzle Replacement: step 2, image 1 of 3 Prusa i3 Mk2  Nozzle Replacement: step 2, image 2 of 3 Prusa i3 Mk2  Nozzle Replacement: step 2, image 3 of 3
      • Remove the 1 X M3 Bolt holding on the fan shroud on the outlet of the fan.
      • Remove the fan shroud.
      • Remove the 2 X M3 Bolts holding on the blower fan.
      • Remove the fan and place it in a safe location.
      • The wires are still attached to the fan, be careful to not break the connectors.
      Ask FixBot
    3. Prusa i3 Mk2  Nozzle Replacement: step 3, image 1 of 1
      • Remove the 2 X M3 Bolts from the Extruder Plate.
      Ask FixBot
    4. Prusa i3 Mk2  Nozzle Replacement: step 4, image 1 of 2 Prusa i3 Mk2  Nozzle Replacement: step 4, image 2 of 2
      • Remove the two M3 Bolts that are holding on the Extruder Cooling Fan.
      • Remove the Extruder Plate carefully, and avoid touching the hot metal print head.
      • Leave one bolt on the back of the fan so that the fan stays attached to the rest of the assembly.
      Ask FixBot
    5. Prusa i3 Mk2  Nozzle Replacement: step 5, image 1 of 1
      • Make sure the nozzle is heated up before doing this step to prevent damage to the print head.
      • Use an adjustable crescent wrench and a 7mm wrench or socket to remove the old nozzle.
      Ask FixBot
    6. Prusa i3 Mk2  Nozzle Replacement: step 6, image 1 of 3 Prusa i3 Mk2  Nozzle Replacement: step 6, image 2 of 3 Prusa i3 Mk2  Nozzle Replacement: step 6, image 3 of 3
      • Screw in the new nozzle using a socket to get the threads started.
      • Use a crescent wrench and a 7mm wrench or socket to tighten a quarter turn past hand tight.
      • Do not over tighten. Damage to the nozzle or print head could occur.
      • Insert some new filament and push it through to test the connection.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Once reassembled, print a test print to ensure the replaced nozzle is not leaking.
6 other people completed this guide.
Aubrey Woern
253 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 22
Past 30 Days: 114
All Time: 11,532
