Proximity Switch Replacement - BallyPal
Featured Document
      • Park the BallyPal and activate the emergency stop button.
      • Use an Allen wrench to unbolt the two (2) 6mm screws on the Display Panel Assembly. Set aside.
      Ask FixBot
      • Unplug the connector from the switch.
      • Using a cross-tip screwdriver, remove the switch from the tiller assembly.
      • Replace with the new interlock (proximity) switch.
      • Reuse screws to secure switch.
      Ask FixBot
      • Insert and tighten screws with Allen wrench to secure the Display Panel Assembly.
      Ask FixBot
Proximity switch has been replaced. Technician should perform an Operations Check to confirm unit is ready for store use.
Attached Documents
Glen Rogers
862 Reputation
6 Guides authored
The Home Depot Member of The Home Depot
Community
28,574 Members
851 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 66
All Time: 473
