Shop the Holiday Gift Guide
Protocol Videodrone AP Battery Wiring Replacement
Views: 2.5K
View statistics:
Past 24 Hours:
6
Past 7 Days:
25
Past 30 Days:
86
All Time:
2,459
Comments: 3
3 guide comments.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 - 20 minutes
Difficulty: Difficult
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Step Trimmer
This guide has unnecessary steps. Trim them to be more concise!
Introduction
Go to step 1 ↓
This guide will show you how to replace the battery and the soldering new wires to the motherboard. This is guide includes a highly recommend soldering guide. CAUTION: Soldering iron will be hot and may cause minor burns if handles improperly.
Tools
    1. Protocol Videodrone AP Battery Wiring  Replacement, Battery Wiring: step 1, image 1 of 1
      • Make sure the drone is turned off
      Ask FixBot
    2. Protocol Videodrone AP Battery Wiring  Replacement: step 2, image 1 of 1
      • Open the hatch and carefully pull out the battery to expose the cable connection
      Ask FixBot
    3. Protocol Videodrone AP Battery Wiring  Replacement: step 3, image 1 of 2 Protocol Videodrone AP Battery Wiring  Replacement: step 3, image 2 of 2
      • Carefully pull apart the cable connection
      Ask FixBot
    4. Protocol Videodrone AP Battery Wiring  Replacement: step 4, image 1 of 2 Protocol Videodrone AP Battery Wiring  Replacement: step 4, image 2 of 2
      • Unscrew the 4 screws from the bottom of the drone.
      • Unscrew the 8 screws connecting the propeller guards to the drone
      • Unscrew the four propeller screws.
      • One screw is hidden behind the screwdriver.
      Ask FixBot
    5. Protocol Videodrone AP Battery Wiring  Replacement: step 5, image 1 of 1
      • Carefully remove faulty battery wiring from the drone
      Ask FixBot
    6. Protocol Videodrone AP Battery Wiring  Replacement: step 6, image 1 of 1
      Tool used on this step:
      Buy
      • Feed through opening using tweezers to grasp the wire and carefully pull through.
      Ask FixBot
    7. Protocol Videodrone AP Battery Wiring  Replacement: step 7, image 1 of 1
      • Use the soldering iron to solder new wires to mother board. CAUTION: Soldering iron may get hot and cause minor burns if handled improperly.
      • Use this guide for how to solder: https://www.youtube.com/watch?v=QKbJxytE...
      Ask FixBot
    8. Protocol Videodrone AP Battery Wiring  Replacement: step 8, image 1 of 1
      • Reattach the battery and test for power by turning on the drone and look for the 4 LEDs turn on.
      Ask FixBot
All Done!
Author
with
Serge
340 Reputation
3 Guides authored
USF Tampa, Team S2-G1, Passmore Fall 2017 Member of USF Tampa, Team S2-G1, Passmore Fall 2017
USFT-PASSMORE-F17S2G1
4 Members
36 Guides authored
3 Guide Comments
Great explanation. Just wondering where to get the replacement piece. My drone has the black wire hanging by a single strand just outside the white connector. The red wire is in tact but I would need the whole part that attaches to the board and extends outside the drone to connect the battery to. Thanks
yasureok - Reply Share
Was wondering i think its charging the blue light flashes when plugged in but wont turn on. Wires look brand new
Michael Landry - Reply Share
I’m wondering the same thing, mine lights up blue when charging, wires look good but still no action.
Ryann Hunter - Reply Share
Past 24 Hours: 6
Past 7 Days: 25
Past 30 Days: 86
All Time: 2,459
