Shop the Holiday Gift Guide
Protocol Vento Motor Replacement
Views: 1.3K
View statistics:
Past 24 Hours:
2
Past 7 Days:
18
Past 30 Days:
56
All Time:
1,252
Comments: 2
2 guide comments.
Go to guide comments
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
The Protocol Vento drone has four motors. Each motor is located at the base of one of the drone's four arms. This guide will demonstrate how to remove and replace a motor.
Parts
Tools
    1. Protocol Vento Motor Replacement, Battery: step 1, image 1 of 1
      • Grasp the tail end of the drone where the lip of the battery protrudes.
      Ask FixBot
    2. Protocol Vento Motor Replacement: step 2, image 1 of 1
      • Pull away from the drone to remove the battery.
      • Do not attempt any repairs or replacements before removing the battery from the drone.
      Ask FixBot
    1. Protocol Vento Motor Replacement, Propeller: step 3, image 1 of 1
      • Place a prying tool under the base of the propeller.
      Ask FixBot
    2. Protocol Vento Motor Replacement: step 4, image 1 of 2 Protocol Vento Motor Replacement: step 4, image 2 of 2
      • Use a moderate amount of force to pry the propeller out of its base. The propeller should pop off.
      Ask FixBot
    1. Protocol Vento Motor Replacement, Motor: step 5, image 1 of 1
      • Unscrew the 4.9mm Phillips #000 screw that is located at the end of the drone's arm.
      Ask FixBot
    2. Protocol Vento Motor Replacement: step 6, image 1 of 2 Protocol Vento Motor Replacement: step 6, image 2 of 2
      • Hold the base of the arm while gently pulling the motor cover away from the arm.
      • Do not pull too hard because there are wires attaching the motor to the drone. Do not sever the wires.
      Ask FixBot
    3. Protocol Vento Motor Replacement: step 7, image 1 of 2 Protocol Vento Motor Replacement: step 7, image 2 of 2
      • Gently pull the motor out from the plastic cover.
      • Do not squeeze or pull too hard, as to not damage the motor connection.
      Ask FixBot
    4. Protocol Vento Motor Replacement: step 8, image 1 of 2 Protocol Vento Motor Replacement: step 8, image 2 of 2
      Tool used on this step:
      Buy
      • The motor’s blue and red wires are secured via a white clip. This clip is inserted into a slot in the drone’s leg.
      • Grasp the clip’s edges with a pair of tweezers and pull outward.
      • Do not pull directly on the wires, as to not separate the wires from the clip.
      Ask FixBot
4 other people completed this guide.
Author
with
Maria Larcomb
926 Reputation
5 Guides authored
USF Tampa, Team S1-G2, Leahy Spring 2018 Member of USF Tampa, Team S1-G2, Leahy Spring 2018
USFT-LEAHY-S18S1G2
4 Members
72 Guides authored
2 Guide Comments
Please send me motor description
suresh virji - Reply Share
send me protocol vento motor
Past 24 Hours: 2
Past 7 Days: 18
Past 30 Days: 56
All Time: 1,252
