Propel Gyro-X Top Propellor Blades Replacement
  1. Propel Gyro-X Top Propellor Blades Replacement, Top Propellor Blades: step 1, image 1 of 1
    • Stabilizing links are easy to break. Be gentle when prying them off.
    • Place the tweezers on the sides of the links and pull straight away from the top point of connection.
  2. Propel Gyro-X Top Propellor Blades Replacement: step 2, image 1 of 2 Propel Gyro-X Top Propellor Blades Replacement: step 2, image 2 of 2
    • Remove the two 6.0 mm Phillips #00 screws from the rotors.
  3. Propel Gyro-X Top Propellor Blades Replacement: step 3, image 1 of 2 Propel Gyro-X Top Propellor Blades Replacement: step 3, image 2 of 2
    • Pull the rotors away from the mounting brackets.
Sarah Atmadja
404 Reputation
3 Guides authored
Cal Poly, Team 17-2, Forte Spring 2015 Member of Cal Poly, Team 17-2, Forte Spring 2015
CPSU-FORTE-S15S17G2
4 Members
7 Guides authored
One Comment
Does any one know where I can buy a stabilizing link?
William M - Reply
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 1,135
