ProTent 2000 Spring in the leg support replacement or readjustment
  1. ProTent 2000 Spring in the leg support replacement or readjustment, Pulling the foot support out of the support leg: step 1, image 1 of 1
    • Pull the foot support out of the support leg.
  2. ProTent 2000 Spring in the leg support replacement or readjustment, Pushing out a faulty or incorrectly seated spring: step 2, image 1 of 2 ProTent 2000 Spring in the leg support replacement or readjustment, Pushing out a faulty or incorrectly seated spring: step 2, image 2 of 2
    • Use a thin rod (eg a cable tube) to push through the support from the foot side and gently push the spring downwards.
    • Pull the spring out of the support leg at the bottom.
  3. ProTent 2000 Spring in the leg support replacement or readjustment, Inserting the spring into the support leg: step 3, image 1 of 2 ProTent 2000 Spring in the leg support replacement or readjustment, Inserting the spring into the support leg: step 3, image 2 of 2
    • Insert the spring with the curved side forward from the foot side into the support leg.
    • The spring bolt must point to the same side as the hole in the bottom of the foot bar.
  4. ProTent 2000 Spring in the leg support replacement or readjustment, Pushing the spring down: step 4, image 1 of 2 ProTent 2000 Spring in the leg support replacement or readjustment, Pushing the spring down: step 4, image 2 of 2
    • Push the spring all the way into the foot.
    • Then put in the rod again and carefully push the spring downwards.
  5. ProTent 2000 Spring in the leg support replacement or readjustment, Placing the spring correctly: step 5, image 1 of 2 ProTent 2000 Spring in the leg support replacement or readjustment, Placing the spring correctly: step 5, image 2 of 2
    • When the spring appears in the hole, continue to push gently until the bolt pops into the hole.
  6. ProTent 2000 Spring in the leg support replacement or readjustment: step 6, image 1 of 1
    • Now push the foot support back into the support leg.
Congratulations, you did it.
Special thanks to these translators:
de en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Markus Mauchle
133 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 7
All Time: 95
