ProScan PLT7223G Motherboard Replacement
  1. ProScan PLT7223G Motherboard Replacement, Motherboard: step 1, image 1 of 1
    • Remove both 4 mm screws from the top of the tablet using a PH00 screw driver.
  2. ProScan PLT7223G Motherboard Replacement: step 2, image 1 of 1
    • Use the blue opening tool to pry the tablet open.
  3. ProScan PLT7223G Motherboard Replacement: step 3, image 1 of 2 ProScan PLT7223G Motherboard Replacement: step 3, image 2 of 2
    • Remove all yellow tape from the motherboard.
  4. ProScan PLT7223G Motherboard Replacement: step 4, image 1 of 3 ProScan PLT7223G Motherboard Replacement: step 4, image 2 of 3 ProScan PLT7223G Motherboard Replacement: step 4, image 3 of 3
    • With the soldering tool remove the speaker wires, battery wires and gray wire that are connected to the motherboard.
    • Pay close attention to where each wire goes, so that you reconnect them in the correct order.
  5. ProScan PLT7223G Motherboard Replacement: step 5, image 1 of 3 ProScan PLT7223G Motherboard Replacement: step 5, image 2 of 3 ProScan PLT7223G Motherboard Replacement: step 5, image 3 of 3
    • Lift all three ZIF connectors to disconnect the ribbon wire.
  6. ProScan PLT7223G Motherboard Replacement: step 6, image 1 of 1
    • Use a PH00 screw driver to remove the three 4 mm screws holding the motherboard down.
  7. ProScan PLT7223G Motherboard Replacement: step 7, image 1 of 1
    • Lift the motherboard off the device.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 9
All Time: 1,483
