Introduction
If your device isn't working and other troubleshooting methods have failed, or a component of the motherboard has failed, use this guide to replace the motherboard and make your device functional again.
  1. Remove both 4 mm screws from the top of the tablet using a PH00 screw driver.
    • Remove both 4 mm screws from the top of the tablet using a PH00 screw driver.
  2. Use the blue opening tool to pry the tablet open.
    • Use the blue opening tool to pry the tablet open.
  3. Remove all yellow tape from the motherboard. Remove all yellow tape from the motherboard.
    • Remove all yellow tape from the motherboard.
  4. Free shipping on all orders over $100 or containing a Pro Tech Toolkit!
    Browse Our Store
  5. With the soldering tool remove the speaker wires, battery wires and gray wire that are connected to the motherboard. Pay close attention to where each wire goes, so that you reconnect them in the correct order. Pay close attention to where each wire goes, so that you reconnect them in the correct order.
    • With the soldering tool remove the speaker wires, battery wires and gray wire that are connected to the motherboard.
    • Pay close attention to where each wire goes, so that you reconnect them in the correct order.
  6. Lift all three ZIF connectors to disconnect the ribbon wire. Lift all three ZIF connectors to disconnect the ribbon wire. Lift all three ZIF connectors to disconnect the ribbon wire.
    • Lift all three ZIF connectors to disconnect the ribbon wire.
  7. Use a PH00 screw driver to remove the three 4 mm screws holding the motherboard down.
    • Use a PH00 screw driver to remove the three 4 mm screws holding the motherboard down.
  8. Lift the motherboard off the device.
    • Lift the motherboard off the device.
One Comment
Once the motherboard is out, what do you do ? Where do I go? More information would be appreciated.
rainbowsend14 - Reply
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 14
All Time: 968
