Shop the Holiday Gift Guide
Keurig 2.0-400 Water Reservoir Replacement
Views: 3.7K
View statistics:
Past 24 Hours:
4
Past 7 Days:
18
Past 30 Days:
82
All Time:
3,698
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 30 seconds
Difficulty: Very easy
Introduction
Go to step 1 ↓
In this guide, you will replace the water reservoir. This is necessary if you want to clean the reservoir or if it does not hold water sufficiently. The water reservoir is transparent and is located on the left side of the Keurig machine.
    1. Keurig 2.0-400 Water Reservoir Replacement, Water Reservoir: step 1, image 1 of 1
      • Locate and grab the Water Reservoir with your hands.
      Ask FixBot
    2. Keurig 2.0-400 Water Reservoir Replacement: step 2, image 1 of 3 Keurig 2.0-400 Water Reservoir Replacement: step 2, image 2 of 3 Keurig 2.0-400 Water Reservoir Replacement: step 2, image 3 of 3
      • Lift the Water Reservoir up. It should be easy to separate it from the main part of the brewer.
      Ask FixBot
Author
with
Alec Jamosmos
972 Reputation
5 Guides authored
Cal Poly, Team S24-G8, Maness Spring 2018 Member of Cal Poly, Team S24-G8, Maness Spring 2018
CPSU-MANESS-S18S24G8
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 18
Past 30 Days: 82
All Time: 3,698
