Introduction
The original program selector switch 1320671207 is no longer available. But it can be replaced with the program selector switch 1243085402 - but this must be re-labeled with a black Edding. Would be a pity to throw away a whole washing machine, if only a small plastic part is no longer available.
First, unscrew the screws at the back of the housing cover with an 8 mm socket wrench.
Now take the new (outer part / ring) of the program selector switch with the Alternative Part No .: 1243085402 and transfer the inscription from the old original (from the removed part) with a thin Fineliner (Edding) and install the whole backwards again. (A is at the top.) 1. clockwise detent! = B; 2. clockwise detent = C, etc.
Should it be necessary to remove the front panel. 1. Disconnect the temperature controller 2. The wash powder drawer kpl. remove (press nose down) 3. unscrew the screws that hide behind the Waschpulverlublade, with a Phillips screwdriver 4. Lever out the lugs left, right and up: remove the panel
Repeat the steps in order to reassemble your device.
Special thanks to these translators:
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
