Printer setup in Linux (Mint, etc)
View statistics:
Past 24 Hours:
4
Past 7 Days:
56
Past 30 Days:
181
All Time:
380
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 minutes
Difficulty: Very easy
Community-Contributed Guide
Introduction
Go to step 1 ↓
Stop your printer spitting out pages of gibberish! On Linux this is generally a driver issue.
      • Connect the printer to your computer with a USB cable.
      • The USB-B plug goes in the back of the printer.
      • Make sure the computer and printer are both switched on.
      Ask FixBot
      • Go to Start menu > System > Printers if it hasn't opened automatically.
      • Now click Add printer and look for the make and model.
      • If you see XP-220 listed in the Epson category, your computer probably has the correct Epson printer driver and you can skip to Step 4.
      • If you don't see XP-220 as an option, pause here and open the software installer (under Start menu > System by default).
      Ask FixBot
      • Linux Mint's stock software "store" has the Epson driver easily available. Search "epson" and the driver should come up as one of, if not the first option.
      • Click Install. Type in the superuser password it asks for (depending on how your account is set up, this may be your own password or an admin's password).
      Ask FixBot
      • When the printer driver is installed, go back to the printer setup.
      • Now when you add your printer, XP-220 will appear in the long list of Epson models. Select that and the computer will now connect to the printer easily.
      Ask FixBot
      • You can print a test page to make sure the printer is working.
      Ask FixBot
This is written for Linux Mint, but also applies to other Linux distributions with similar menu options.
Sparky
1,827 Reputation
13 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 56
Past 30 Days: 181
All Time: 380
