First remove the 2 Phillips head screws on the front of the power cover.
BEWARE : this may be more difficult if on carpet and may require another person to push the chair off the floor.
Using a Philips head screw driver preferable Size 1 , remove the 5 screws.
Once all screws are removed , Place your hands where the red rectangles are marked, Place your fingers under the lip of that cover and give a slight pull upwards.
Take Care when removing this cover as there is a wire running across it.
To reassemble your device, follow these instructions in reverse order. Be sure you are snapping the ball and joint pieces back together when your are reassembling .
