Introduction
This guide will outline the steps involved in replacing the main board of an iHome iP37
Tool used on this step:iOpener$19.99
Pry the exterior housing off the iHome iP37. You may need extra leverage to do this.
Remove these four 9 mm screws from the plastic casing; you will need a Phillips #2 driver to do this.
Remove the flanged 9 mm screw from the counterweight; you will need a Phillips #2 driver to do this.
Lift and remove the counterweight.
Remove the two #2 screws that hold the main printed circuit board onto the rest of the iP37; you will need a Phillips #2 driver to do this.
Slowly lift the PCB away from the rest of the device
Remove the ribbon by first removing the brown insert piece from the connector on the button board
Pull the ribbon out of the connector on the button board by the blue tab.
