Community-Contributed Guide
Parts
Remove all the following screws:
Red M2.5×6 (16 pieces)
青 M2×5 (2本)
Remove the warning label and S/N label.
Remove the bottom exterior
Remove all screws that secure the airtight module to the housing
Red M2.5×12 (8 pieces)
Blue M2 x 5 (4 pieces)
Remove all screws from the airtight module
M2.5x8 (48 pieces)
Remove all the screws that attach the camera module
M2x5 (8 Pieces)
Remove the screws circled in red. M2×5 (2 pieces)
Remove the heatsink indicated by the orange arrow.
Unlock the flexible cable connector (raise the black lock)
The ferrite core indicated by the orange arrow will be reused, so keep it.
Cut the white magnet cable (red circle position)
Remove the LED connector (blue circle position)
After confirming that the flexible cable, magnet cable, and LED cable have been removed, pull out the camera module.
Insert the camera cable into the main unit from the arrow position (flexible cable, magnet cable, LED cable)
Check that the O-ring is not scratched, cut, or damaged, apply grease to it and fit it firmly into the groove.
Attach the camera module to the mount
Tighten diagonally a little at a time, tightening to a torque of 4.9 [cN・m].
Finally, tighten it one more time at 4.9 [cN・m]
Insert the ferrite core that you removed earlier.
Remove the Kapton tape from the end of the cable.
Install the flexible cable
Replace the double-sided tape on the back of the heat sink
Remove the release paper from the double-sided tape and secure it with M2 x 5 (2 pieces).
Peel off the coating of the magnetic cable on the main unit and insert the shrink tube.
Solder the cable on the main unit and the cable on the camera.
Fix the shrink tube with a heat gun
The LED lights up just like in the picture.
Startup sound is normal
All motors and cameras are functioning normally.
Check that both O-rings are free of scratches, damage, and dirt, and apply grease to them and align them with the grooves.
Close the upper module, being careful not to catch any cables or debris.
Place the plate on and tighten all 48 screws
M2.5 x 8 (48 pieces)
Tightening torque = 39 [cN・m]
Install the M2.5 x 12 (8) screws.
Insert translation here
Remove the silicone sealant
Remove the airtight bolt with a 3mm hexagonal wrench
Install the airtight test bolt in the place where the airtight bolt was removed.
Attach the hose and pump to the airtight test bolt
Pressurize to 140kPa, submerge in water, and check for no leaks for 3 minutes.
Remove the airtight test bolt
Wrap the O-ring and sealing tape around the airtight bolt that you just removed and install it.
Attach the four exterior parts
Attach the safety seal and S/N seal
Special thanks to these translators:
100%
BTL Repair AU is helping us fix the world! Want to contribute?
Start translating ›
