You're viewing a previously published version of this guide. View latest version
The bottom case slides off easily after removing a few T8 Torx screws.
Turn the G4 over.
Remove the eight T8 Torx screws from the lower case.
Using your thumbs, slide the lower case away from you.
The lower case may stick in the front on a tab just above the center of the DVD drive. Be careful as you work the case off, or you may break the thin strip of plastic just above the drive.
Lift the lower case off.
Your laptop should look approximately like this.
G4-Ti-Onyx-Screw-Guide.pdf
PDF - 324.52 kb
with 2 other contributors
1 Reputation
636 Guides authored
Badges: 36
+33 more badges
Choose a size and copy the code below to embed this guide as a small widget on your site / forum.
Past 24 Hours: 1
Past 7 Days: 12
Past 30 Days: 17
All Time: 4,112
