PowerBook G4 Titanium DVI Optical Drive Removal Replacement
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. PowerBook G4 Titanium DVI Optical Drive Removal Replacement, Battery: step 1, image 1 of 2 PowerBook G4 Titanium DVI Optical Drive Removal Replacement, Battery: step 1, image 2 of 2
    • Locate the battery release tab on the underside of the G4.
    • Slide the battery release tab to the left and lift the battery out of the computer.
  2. PowerBook G4 Titanium DVI Optical Drive Removal Replacement, Lower Case: step 2, image 1 of 2 PowerBook G4 Titanium DVI Optical Drive Removal Replacement, Lower Case: step 2, image 2 of 2
    • Remove the seven T8 Torx screws from the lower case.
    • Using your thumbs, slide the lower case toward the front of the computer.
    • The lower case may stick in the front on a tab just above the center of the optical drive. Be careful as you work the case off, or you may break the thin strip of plastic just above the drive.
    • Lift the lower case off.
  3. PowerBook G4 Titanium DVI Optical Drive Removal Replacement, Hard Drive: step 3, image 1 of 1
    • Disconnect the hard drive ribbon from the logic board using a spudger or the tip of your finger.
  4. PowerBook G4 Titanium DVI Optical Drive Removal Replacement: step 4, image 1 of 1
    • To free the hard drive, remove the two T8 Torx screws from the right wall of the battery housing.
  5. PowerBook G4 Titanium DVI Optical Drive Removal Replacement: step 5, image 1 of 1
    • Remove the hard drive by lifting the left edge up and out of the computer.
    • There are four rubber bumpers that fit over the hard drive screws. Ensure that these bumpers come out when you remove the hard drive.
  6. PowerBook G4 Titanium DVI Optical Drive Removal Replacement: step 6, image 1 of 1
    • Your laptop should look approximately like this.
  7. PowerBook G4 Titanium DVI Optical Drive Removal Replacement, Optical Drive Removal: step 7, image 1 of 1
    • Disconnect and remove the indicated orange ribbon cable.
  8. PowerBook G4 Titanium DVI Optical Drive Removal Replacement: step 8, image 1 of 1
    • Disconnect the pink and white inverter cable from the inverter board.
    • The display inverter has orange plastic shielding around it that looks similar to the tape used elsewhere within the computer. Do not remove the shielding from the inverter.
  9. PowerBook G4 Titanium DVI Optical Drive Removal Replacement: step 9, image 1 of 1
    • Remove the two silver T8 Torx screws from the black plastic bar.
    • Lift the black plastic bar out.
    • Reassembly will be significantly easier if you reseat the hard drive before returning the black bar to its place.
  10. PowerBook G4 Titanium DVI Optical Drive Removal Replacement: step 10, image 1 of 1
    • Disconnect the two orange connectors from the logic board, removing tape as necessary.
  11. PowerBook G4 Titanium DVI Optical Drive Removal Replacement: step 11, image 1 of 1
    • Lift the drive up on the right side so that you can access and disconnect the modem cable and inverter cable.
  12. PowerBook G4 Titanium DVI Optical Drive Removal Replacement: step 12, image 1 of 1
    • Remove the drive by lifting the right edge up and out of the computer.
Attached Documents
iRobot
1 Reputation
636 Guides authored
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 12
All Time: 9,831
