Installing PowerBook G4 Titanium DVI Modem
  1. Installing PowerBook G4 Titanium DVI Modem, Battery: step 1, image 1 of 2 Installing PowerBook G4 Titanium DVI Modem, Battery: step 1, image 2 of 2
    • Locate the battery release tab on the underside of the G4.
    • Slide the battery release tab to the left and lift the battery out of the computer.
  2. Installing PowerBook G4 Titanium DVI Modem, Lower Case: step 2, image 1 of 2 Installing PowerBook G4 Titanium DVI Modem, Lower Case: step 2, image 2 of 2
    • Remove the seven T8 Torx screws from the lower case.
    • Using your thumbs, slide the lower case toward the front of the computer.
    • The lower case may stick in the front on a tab just above the center of the optical drive. Be careful as you work the case off, or you may break the thin strip of plastic just above the drive.
    • Lift the lower case off.
  3. Installing PowerBook G4 Titanium DVI Modem, Airport Card: step 3, image 1 of 1
    • Firmly grasp the plastic tab attached to the Airport card and pull up and to the left.
    • Disconnect the antenna cable from the left side of the Airport card.
  4. Installing PowerBook G4 Titanium DVI Modem, Hard Drive: step 4, image 1 of 1
    • Disconnect the hard drive ribbon from the logic board using a spudger or the tip of your finger.
  5. Installing PowerBook G4 Titanium DVI Modem: step 5, image 1 of 1
    • To free the hard drive, remove the two T8 Torx screws from the right wall of the battery housing.
  6. Installing PowerBook G4 Titanium DVI Modem: step 6, image 1 of 1
    • Remove the hard drive by lifting the left edge up and out of the computer.
    • There are four rubber bumpers that fit over the hard drive screws. Ensure that these bumpers come out when you remove the hard drive.
  7. Installing PowerBook G4 Titanium DVI Modem: step 7, image 1 of 1
    • Your laptop should look approximately like this.
  8. Installing PowerBook G4 Titanium DVI Modem, Optical Drive Removal: step 8, image 1 of 1
    • Disconnect and remove the indicated orange ribbon cable.
  9. Installing PowerBook G4 Titanium DVI Modem: step 9, image 1 of 1
    • Disconnect the pink and white inverter cable from the inverter board.
    • The display inverter has orange plastic shielding around it that looks similar to the tape used elsewhere within the computer. Do not remove the shielding from the inverter.
  10. Installing PowerBook G4 Titanium DVI Modem: step 10, image 1 of 1
    • Remove the two silver T8 Torx screws from the black plastic bar.
    • Lift the black plastic bar out.
    • Reassembly will be significantly easier if you reseat the hard drive before returning the black bar to its place.
  11. Installing PowerBook G4 Titanium DVI Modem: step 11, image 1 of 1
    • Disconnect the two orange connectors from the logic board, removing tape as necessary.
  12. Installing PowerBook G4 Titanium DVI Modem: step 12, image 1 of 1
    • Lift the drive up on the right side so that you can access and disconnect the modem cable and inverter cable.
  13. Installing PowerBook G4 Titanium DVI Modem: step 13, image 1 of 1
    • Remove the drive by lifting the right edge up and out of the computer.
  14. Installing PowerBook G4 Titanium DVI Modem, Modem: step 14, image 1 of 1
    • Remove the two T6 Torx screws from the modem.
    • Lift the modem off the optical drive, carefully guiding the orange ribbon cable through the space in the drive mount.
Attached Documents
iRobot
1 Reputation
636 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 13
All Time: 3,305
