Installing PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) Battery
  1. Installing PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) Battery, Battery: step 1, image 1 of 2 Installing PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) Battery, Battery: step 1, image 2 of 2
    • Use your thumbs to push the two battery retaining tabs away from the battery.
    • The battery should pop up enough to rotate it toward yourself and lift it out of the lower case.
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 15
All Time: 3,144
