PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) Battery Replacement
  1. PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) Battery Replacement, Battery: step 1, image 1 of 2 PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) Battery Replacement, Battery: step 1, image 2 of 2
    • Use your thumbs to push the two battery retaining tabs away from the battery.
    • The battery should pop up enough to rotate it toward yourself and lift it out of the lower case.
Attached Documents
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 19
All Time: 3,130
