Installing PowerBook G4 Aluminum 15" 1.5-1.67 GHz PRAM Battery
  1. Installing PowerBook G4 Aluminum 15" 1.5-1.67 GHz PRAM Battery, Battery: step 1, image 1 of 1
    • Use a coin or a spudger to turn the battery locking screw 90 degrees clockwise.
    • Lift the battery out of the computer.
  2. Installing PowerBook G4 Aluminum 15" 1.5-1.67 GHz PRAM Battery, Upper Case: step 2, image 1 of 1
    • Remove the four Phillips screws from the memory door.
    • Slide the memory door away from the memory compartment.
  3. Installing PowerBook G4 Aluminum 15" 1.5-1.67 GHz PRAM Battery: step 3, image 1 of 1
    • Remove the following 8 screws:
    • Two 3 mm Phillips in the battery compartment, on either side of the battery contacts.
    • Two 12 mm Phillips on either side of the memory compartment.
    • Four 16 mm Phillips along the hinge.
  4. Installing PowerBook G4 Aluminum 15" 1.5-1.67 GHz PRAM Battery: step 4, image 1 of 1
    • Rotate the computer 90 degrees clockwise, so that the power receptacle faces you.
    • Remove the three 3 mm Phillips screws.
    • When replacing these screws, you must place each screw in the correct order. Begin by installing the screw closest to the display hinge, and go out from there.
  5. Installing PowerBook G4 Aluminum 15" 1.5-1.67 GHz PRAM Battery: step 5, image 1 of 1
    • Turn the computer 90 degrees clockwise so that the hinge faces you.
    • Remove the bottom 5 mm Phillips screw on either side of the hinge (two total).
  6. Installing PowerBook G4 Aluminum 15" 1.5-1.67 GHz PRAM Battery: step 6, image 1 of 1
    • Rotate the computer 90 degrees clockwise, so that the ports face you.
  7. Installing PowerBook G4 Aluminum 15" 1.5-1.67 GHz PRAM Battery: step 7, image 1 of 1
    • Turn the computer over and open the display.
    • Remove the two 1.5 mm hex screws in either corner, next to the display (a T6 Torx driver will work, but repeated use will strip the screws).
  8. Installing PowerBook G4 Aluminum 15" 1.5-1.67 GHz PRAM Battery: step 8, image 1 of 1
    • Grasp the back corners of the upper case and pull up. Do not pull the upper case off yet; you still need to disconnect the keyboard and trackpad cable.
    • Lift the back of the case up and work your fingers along the sides, freeing the case as you go. Once you have freed the sides, you may need to rock the case up and down to free the front of the upper case.
  9. Installing PowerBook G4 Aluminum 15" 1.5-1.67 GHz PRAM Battery: step 9, image 1 of 1
    • Rotate the upper case up and toward the screen, so that the upper case rests against it.
  10. Installing PowerBook G4 Aluminum 15" 1.5-1.67 GHz PRAM Battery: step 10, image 1 of 1
    • Remove the orange tape securing the trackpad ribbon to the logic board.
    • Disconnect the trackpad ribbon from the logic board.
    • Remove the upper case from the computer.
  11. Installing PowerBook G4 Aluminum 15" 1.5-1.67 GHz PRAM Battery, PRAM Battery: step 11, image 1 of 1
    • Use a spudger to pry up the PRAM battery from the optical drive.
  12. Installing PowerBook G4 Aluminum 15" 1.5-1.67 GHz PRAM Battery: step 12, image 1 of 1
    • Disconnect the PRAM battery cable from the logic board and pull the PRAM battery out, removing tape as necessary.
Attached Documents
iRobot
1 Reputation
636 Guides authored
Past 24 Hours: 0
Past 7 Days: 9
Past 30 Days: 22
All Time: 34,905
