Installing PowerBook G4 Aluminum 12" 867 MHz Airport Extreme Card
  1. Installing PowerBook G4 Aluminum 12" 867 MHz Airport Extreme Card, Battery: step 1, image 1 of 1
    • Use a coin to turn the battery locking screw 90 degrees to the right.
    • Lift the battery out of the computer.
  2. Installing PowerBook G4 Aluminum 12" 867 MHz Airport Extreme Card, Airport Extreme Card: step 2, image 1 of 1
    • Flip down the door on the right side of the battery compartment.
  3. Installing PowerBook G4 Aluminum 12" 867 MHz Airport Extreme Card: step 3, image 1 of 1
    • Use a spudger to disconnect the Airport antenna from the card.
  4. Installing PowerBook G4 Aluminum 12" 867 MHz Airport Extreme Card: step 4, image 1 of 1
    • Grasp the plastic tab and pull the card out all the way.
Attached Documents
iRobot
1 Reputation
636 Guides authored
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 17
All Time: 10,855
