Installing PowerBook G3 Wallstreet Modem
  1. Installing PowerBook G3 Wallstreet Modem, Keyboard: step 1, image 1 of 1
    • Remove both expansion bay modules using the levers on the front of the computer.
    • Insert your index fingers inside the expansion bays and search for the two ribbed tabs on the underside of the upper case. The tabs are located near the bottom corners of the keyboard.
    • Pull the tabs toward yourself and the keyboard will pop up.
  2. Installing PowerBook G3 Wallstreet Modem: step 2, image 1 of 1
    • Pull the keyboard forward to disengage the tabs holding it in back and rotate it toward you.
    • Rest the keyboard on the trackpad.
    • This is a diagram of the ribbon clamp connectors you will disconnect in the next step.
    • 1) With your fingernails, grasp the locking bar on either side and pull up a small amount (about 1/16" or 2 mm).
    • 2) After disengaging the locking bar, slide the cable out of the connector.
  3. Installing PowerBook G3 Wallstreet Modem: step 4, image 1 of 1
    • Disconnect the two keyboard connectors by disengaging the clamps and pulling the ribbons directly upward.
  4. Installing PowerBook G3 Wallstreet Modem: step 5, image 1 of 1
    • Slide a spudger downward between each plastic strain relief cable and the wall of the case in order to bow out the cable beyond the small tab holding it in place.
    • Once the strain relief cables are free, lift the keyboard off.
  5. Installing PowerBook G3 Wallstreet Modem: step 6, image 1 of 1
    • Your laptop should look approximately like this.
  6. Installing PowerBook G3 Wallstreet Modem, Heat Shield: step 7, image 1 of 1
    • Remove the two Phillips screws from the heat shield.
    • One screw is shorter than the other. When putting the Wallstreet back together, this screw goes in the middle of the heat shield.
  7. Installing PowerBook G3 Wallstreet Modem: step 8, image 1 of 1
    • Grasp the metal handle on the heat shield and pull up and toward yourself.
  8. Installing PowerBook G3 Wallstreet Modem, Hard Drive: step 9, image 1 of 1
    • Unscrew, but do not remove, the single Phillips screw from the hard drive bracket.
  9. Installing PowerBook G3 Wallstreet Modem: step 10, image 1 of 1
    • Grasp the hard drive bracket on the left side and pull up and to the left.
  10. Installing PowerBook G3 Wallstreet Modem: step 11, image 1 of 1
  11. Installing PowerBook G3 Wallstreet Modem, Processor: step 12, image 1 of 1
    • Use a spudger, the tips of your fingers, or a flat non-metal tool to pry up the processor's right side.
    • Remove the processor by sliding it up and to the right.
    • The processor and RAM can be removed as a unit. It is not necessary to remove the RAM from the processor.
    • There are two tabs on the left side of the processor that fit into slots on the metal framework. Make sure these tabs are in the slots.
  12. Installing PowerBook G3 Wallstreet Modem, Modem: step 13, image 1 of 1
    • Remove the single Phillips screw from the modem.
    • Disconnect the orange PMU cable by pulling it directly up.
  13. Installing PowerBook G3 Wallstreet Modem: step 14, image 1 of 1
    • Disconnect the modem from the logic board by lifting up on the right side using a spudger, the tip of your finger, or a flat non-metal tool.
    • Remove the modem by sliding it up and to the right.
  14. Installing PowerBook G3 Wallstreet Modem: step 15, image 1 of 1
iRobot
1 Reputation
636 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 3,265
