Replacing PowerBook G3 Wallstreet Hard Drive
  1. Replacing PowerBook G3 Wallstreet Hard Drive, Keyboard: step 1, image 1 of 1
    • Remove both expansion bay modules using the levers on the front of the computer.
    • Insert your index fingers inside the expansion bays and search for the two ribbed tabs on the underside of the upper case. The tabs are located near the bottom corners of the keyboard.
    • Pull the tabs toward yourself and the keyboard will pop up.
  2. Replacing PowerBook G3 Wallstreet Hard Drive: step 2, image 1 of 1
    • Pull the keyboard forward to disengage the tabs holding it in back and rotate it toward you.
    • Rest the keyboard on the trackpad.
    • This is a diagram of the ribbon clamp connectors you will disconnect in the next step.
    • 1) With your fingernails, grasp the locking bar on either side and pull up a small amount (about 1/16" or 2 mm).
    • 2) After disengaging the locking bar, slide the cable out of the connector.
  3. Replacing PowerBook G3 Wallstreet Hard Drive: step 4, image 1 of 1
    • Disconnect the two keyboard connectors by disengaging the clamps and pulling the ribbons directly upward.
  4. Replacing PowerBook G3 Wallstreet Hard Drive: step 5, image 1 of 1
    • Slide a spudger downward between each plastic strain relief cable and the wall of the case in order to bow out the cable beyond the small tab holding it in place.
    • Once the strain relief cables are free, lift the keyboard off.
  5. Replacing PowerBook G3 Wallstreet Hard Drive: step 6, image 1 of 1
    • Your laptop should look approximately like this.
  6. Replacing PowerBook G3 Wallstreet Hard Drive, Heat Shield: step 7, image 1 of 1
    • Remove the two Phillips screws from the heat shield.
    • One screw is shorter than the other. When putting the Wallstreet back together, this screw goes in the middle of the heat shield.
  7. Replacing PowerBook G3 Wallstreet Hard Drive: step 8, image 1 of 1
    • Grasp the metal handle on the heat shield and pull up and toward yourself.
  8. Replacing PowerBook G3 Wallstreet Hard Drive, Hard Drive: step 9, image 1 of 1
    • Unscrew, but do not remove, the single Phillips screw from the hard drive bracket.
  9. Replacing PowerBook G3 Wallstreet Hard Drive: step 10, image 1 of 1
    • Grasp the hard drive bracket on the left side and pull up and to the left.
  10. Replacing PowerBook G3 Wallstreet Hard Drive: step 11, image 1 of 1
  11. Replacing PowerBook G3 Wallstreet Hard Drive, Replacing PowerBook G3 Wallstreet Hard Drive: step 12, image 1 of 1
    • Remove the four T8 Torx screws from the hard drive bracket.
  12. Replacing PowerBook G3 Wallstreet Hard Drive: step 13, image 1 of 1
    • Turn the hard drive bracket over.
    • Hold the hard drive bracket at the connector end and grasp the opposite end of the hard drive.
    • Pull the hard drive out of the bracket, making sure to pull evenly on both sides.
Attached Documents
iRobot
1 Reputation
636 Guides authored
Past 24 Hours: 0
Past 7 Days: 11
Past 30 Days: 63
All Time: 22,481
