Installing PowerBook G3 Pismo Processor
  1. Installing PowerBook G3 Pismo Processor, Keyboard: step 1, image 1 of 1
    • Turn the keyboard locking screw so that it is parallel to the space bar.
    • Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
    • Lift the keyboard out by pulling it up and away from you. Rest the keyboard, face down, on top of the track pad.
  2. Installing PowerBook G3 Pismo Processor: step 2, image 1 of 1
    • Pull the keyboard ribbon straight up from the logic board. Place the keyboard aside.
    • The connector may be tight. Gently rock the connector from side to side while pulling directly upward to free it. You can use this technique on many of the cards and cables you'll be disconnecting.
    • Make sure you have removed the laptop battery and CD/DVD modules from the expansion bays before proceeding.
  3. Installing PowerBook G3 Pismo Processor: step 3, image 1 of 1
    • Your laptop should look approximately like this.
  4. Installing PowerBook G3 Pismo Processor, Heat Shield: step 4, image 1 of 1
    • Remove the two silver Phillips #1 screws that attach the heat shield to the internal metal framework.
    • Lift the heat shield up and pull it toward you.
  5. Installing PowerBook G3 Pismo Processor: step 5, image 1 of 1
  6. Installing PowerBook G3 Pismo Processor, Airport Card: step 6, image 1 of 1
    • Skip this step if your computer does not have an Airport card installed.
    • Firmly grasp the plastic tab attached to the Airport card and pull up and then to the right.
    • The Airport card is still attached to the antenna cable, so don't just yank it out of the slot.
  7. Installing PowerBook G3 Pismo Processor: step 7, image 1 of 1
    • Disconnect the antenna cable from the Airport card.
  8. Installing PowerBook G3 Pismo Processor, PRAM Battery: step 8, image 1 of 1
    • Pull the battery cable directly up from the logic board.
    • Remove the battery from its holder by pulling up and to the left.
  9. Installing PowerBook G3 Pismo Processor: step 9, image 1 of 1
  10. Installing PowerBook G3 Pismo Processor, Heat Sink: step 10, image 1 of 1
    • Remove the long silver Phillips #1 screw from the heat sink.
    • Remove the two T8 Torx screws that attach the heat sink to the processor.
  11. Installing PowerBook G3 Pismo Processor: step 11, image 1 of 1
    • Lift the heat sink up from the left side and pull it out.
    • If you need to mount the heat sink back into the laptop, we have a thermal paste guide that makes replacing the thermal compound easy.
  12. Installing PowerBook G3 Pismo Processor, Processor: step 12, image 1 of 1
    • Grasp the plastic tab on the processor's right side and pull it directly up.
    • Some processors may be missing the plastic pull tab. In this case, we suggest using a non-metal tool to gently pry up the processor. Slip the tool's thin edge under the front right corner of the processor and carefully pry it up.
  13. Installing PowerBook G3 Pismo Processor: step 13, image 1 of 1
iRobot
1 Reputation
636 Guides authored
Past 24 Hours: 2
Past 7 Days: 14
Past 30 Days: 25
All Time: 9,023
