Installing PowerBook G3 Pismo Optical Drive
  1. Installing PowerBook G3 Pismo Optical Drive, Optical Drive: step 1, image 1 of 1
    • Use the lever at the front of your laptop to remove the optical drive bay from the computer.
    • Remove the 2 Phillips #00 screws from the left side of the optical drive housing.
    • These screws are longer than those on the other side.
  2. Installing PowerBook G3 Pismo Optical Drive: step 2, image 1 of 1
    • Remove the 2 Phillips #00 screws from the other side.
  3. Installing PowerBook G3 Pismo Optical Drive: step 3, image 1 of 1
    • Grasp the black drive housing in one hand and the drive itself in the other, then slide the two apart.
    • If you have a CD or any other object jammed in your optical drive, we have an optical drive repair guide.
Attached Documents
iRobot
1 Reputation
636 Guides authored
Past 24 Hours: 2
Past 7 Days: 2
Past 30 Days: 9
All Time: 8,685
