Installing PowerBook G3 Pismo Hard Drive
  1. Installing PowerBook G3 Pismo Hard Drive, Keyboard: step 1, image 1 of 1
    • Turn the keyboard locking screw so that it is parallel to the space bar.
    • Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
    • Lift the keyboard out by pulling it up and away from you. Rest the keyboard, face down, on top of the track pad.
  2. Installing PowerBook G3 Pismo Hard Drive: step 2, image 1 of 1
    • Pull the keyboard ribbon straight up from the logic board. Place the keyboard aside.
    • The connector may be tight. Gently rock the connector from side to side while pulling directly upward to free it. You can use this technique on many of the cards and cables you'll be disconnecting.
    • Make sure you have removed the laptop battery and CD/DVD modules from the expansion bays before proceeding.
  3. Installing PowerBook G3 Pismo Hard Drive: step 3, image 1 of 1
    • Your laptop should look approximately like this.
  4. Installing PowerBook G3 Pismo Hard Drive, Heat Shield: step 4, image 1 of 1
    • Remove the two silver Phillips #1 screws that attach the heat shield to the internal metal framework.
    • Lift the heat shield up and pull it toward you.
  5. Installing PowerBook G3 Pismo Hard Drive: step 5, image 1 of 1
  6. Installing PowerBook G3 Pismo Hard Drive, Airport Card: step 6, image 1 of 1
    • Skip this step if your computer does not have an Airport card installed.
    • Firmly grasp the plastic tab attached to the Airport card and pull up and then to the right.
    • The Airport card is still attached to the antenna cable, so don't just yank it out of the slot.
  7. Installing PowerBook G3 Pismo Hard Drive: step 7, image 1 of 1
    • Disconnect the antenna cable from the Airport card.
  8. Installing PowerBook G3 Pismo Hard Drive, Heat Sink: step 8, image 1 of 1
    • Remove the long silver Phillips #1 screw from the heat sink.
    • Remove the two T8 Torx screws that attach the heat sink to the processor.
  9. Installing PowerBook G3 Pismo Hard Drive: step 9, image 1 of 1
    • Lift the heat sink up from the left side and pull it out.
    • If you need to mount the heat sink back into the laptop, we have a thermal paste guide that makes replacing the thermal compound easy.
  10. Installing PowerBook G3 Pismo Hard Drive, Processor: step 10, image 1 of 1
    • Grasp the plastic tab on the processor's right side and pull it directly up.
    • Some processors may be missing the plastic pull tab. In this case, we suggest using a non-metal tool to gently pry up the processor. Slip the tool's thin edge under the front right corner of the processor and carefully pry it up.
  11. Installing PowerBook G3 Pismo Hard Drive: step 11, image 1 of 1
  12. Installing PowerBook G3 Pismo Hard Drive, Hard Drive: step 12, image 1 of 1
    • Grasp the orange cable at the left end of the hard drive and disconnect it from the logic board.
    • Try to grasp the cable on the plastic connector rather than on the flexible cable section.
  13. Installing PowerBook G3 Pismo Hard Drive: step 13, image 1 of 1
    • Grasp the plastic tab and pull the hard drive up and to the left, making sure that the metal bracket doesn't catch on the black plastic casing.
  14. Installing PowerBook G3 Pismo Hard Drive: step 14, image 1 of 1
iRobot
1 Reputation
636 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 6,288
