Installing PowerBook G3 Lombard PRAM Battery
  1. Installing PowerBook G3 Lombard PRAM Battery, Keyboard: step 1, image 1 of 1
    • Turn the computer so that the ports are facing you.
    • If the keyboard is locked, open the port cover and turn the keyboard locking screw until the keyboard is unlocked.
  2. Installing PowerBook G3 Lombard PRAM Battery: step 2, image 1 of 1
    • Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
    • Make sure you have removed the laptop battery and CD/DVD module from the expansion bays before proceeding.
  3. Installing PowerBook G3 Lombard PRAM Battery: step 3, image 1 of 1
    • Lift the keyboard out by pulling it up and away from you. Rest the keyboard, face down, on top of the trackpad.
    • In order to replace the keyboard, you must first remove the modem.
  4. Installing PowerBook G3 Lombard PRAM Battery, Heat Shield: step 4, image 1 of 1
    • Remove the three silver Phillips screws that attach the heat shield to the internal metal framework.
  5. Installing PowerBook G3 Lombard PRAM Battery: step 5, image 1 of 1
    • Lift the heat shield up and pull it toward you.
  6. Installing PowerBook G3 Lombard PRAM Battery: step 6, image 1 of 1
    • Your laptop should look approximately like this.
  7. Installing PowerBook G3 Lombard PRAM Battery, PRAM Battery: step 7, image 1 of 1
    • Pull the battery cable directly up from the logic board.
  8. Installing PowerBook G3 Lombard PRAM Battery: step 8, image 1 of 1
    • Remove the battery from its holder by pulling up and to the left.
Attached Documents
iRobot
1 Reputation
636 Guides authored
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 16
All Time: 10,965
