Installing PowerBook G3 Lombard Lower Case
  1. Installing PowerBook G3 Lombard Lower Case, Keyboard: step 1, image 1 of 1
    • Turn the computer so that the ports are facing you.
    • If the keyboard is locked, open the port cover and turn the keyboard locking screw until the keyboard is unlocked.
  2. Installing PowerBook G3 Lombard Lower Case: step 2, image 1 of 1
    • Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
    • Make sure you have removed the laptop battery and CD/DVD module from the expansion bays before proceeding.
  3. Installing PowerBook G3 Lombard Lower Case: step 3, image 1 of 1
    • Lift the keyboard out by pulling it up and away from you. Rest the keyboard, face down, on top of the trackpad.
    • In order to replace the keyboard, you must first remove the modem.
  4. Installing PowerBook G3 Lombard Lower Case, Heat Shield: step 4, image 1 of 1
    • Remove the three silver Phillips screws that attach the heat shield to the internal metal framework.
  5. Installing PowerBook G3 Lombard Lower Case: step 5, image 1 of 1
    • Lift the heat shield up and pull it toward you.
  6. Installing PowerBook G3 Lombard Lower Case: step 6, image 1 of 1
    • Your laptop should look approximately like this.
  7. Installing PowerBook G3 Lombard Lower Case, PRAM Battery: step 7, image 1 of 1
    • Pull the battery cable directly up from the logic board.
  8. Installing PowerBook G3 Lombard Lower Case: step 8, image 1 of 1
    • Remove the battery from its holder by pulling up and to the left.
  9. Installing PowerBook G3 Lombard Lower Case, Modem: step 9, image 1 of 1
    • Remove the two silver Phillips screws from the modem.
  10. Installing PowerBook G3 Lombard Lower Case: step 10, image 1 of 1
    • Use a spudger, the tips of your fingers, or a flat non-metal tool to get under the modem's edge and pry it up from its socket as shown in the picture.
  11. Installing PowerBook G3 Lombard Lower Case: step 11, image 1 of 1
    • Disconnect the cable from the right side of the modem.
  12. Installing PowerBook G3 Lombard Lower Case: step 12, image 1 of 1
  13. Installing PowerBook G3 Lombard Lower Case, Processor: step 13, image 1 of 1
    • Use a spudger, the tips of your fingers, or a flat non-metal tool to pry up the processor's right side.
  14. Installing PowerBook G3 Lombard Lower Case: step 14, image 1 of 1
    • Disconnect the keyboard cable from the logic board by pulling directly up on the clear plastic loop.
    • This step is out of sequence with the keyboard because in order to remove the keyboard you must first remove the modem.
  15. Installing PowerBook G3 Lombard Lower Case: step 15, image 1 of 1
  16. Installing PowerBook G3 Lombard Lower Case, RAM: step 16, image 1 of 1
    • Release the tabs on each side of the RAM chip at the same time. These tabs lock the chip in place and releasing them will cause the chip to "pop" up.
    • Pull the RAM chip out.
    • There are RAM slots on both sides of the processor. We recommend installing higher capacity chips on the bottom so that if you want to upgrade later, you won't have to remove the processor.
  17. Installing PowerBook G3 Lombard Lower Case, Hard Drive: step 17, image 1 of 1
    • Grasp the orange cable at the left end of the hard drive and disconnect it from the logic board.
    • Try to grasp the cable on the plastic connector rather than on the flexible cable section.
  18. Installing PowerBook G3 Lombard Lower Case: step 18, image 1 of 1
    • Grasp the plastic tab and pull the hard drive up and to the left, making sure that the metal bracket doesn't catch on the black plastic casing.
  19. Installing PowerBook G3 Lombard Lower Case, Clutch Cover: step 19, image 1 of 1
    • Push the display back so that it lies flat.
  20. Installing PowerBook G3 Lombard Lower Case: step 20, image 1 of 1
    • Slip a spudger or your index finger under the clutch cover near the power button and pull gently upward until you feel it come free.
    • Repeat the previous step on the left side.
  21. Installing PowerBook G3 Lombard Lower Case: step 21, image 1 of 1
    • Lift the clutch cover up and off, rotating it toward yourself.
  22. Installing PowerBook G3 Lombard Lower Case, Inverter: step 22, image 1 of 1
    • Grasp the orange display data cable and disconnect it from the logic board.
    • Pull the display cable straight up so that it is vertical.
  23. Installing PowerBook G3 Lombard Lower Case: step 23, image 1 of 1
    • Grasp the thin display inverter board at its left end, push the left end forward to get the board beyond the tab, and then lift the entire board up.
    • There are two tabs that hold the display inverter in place that you need to get past in order to pull the board free.
  24. Installing PowerBook G3 Lombard Lower Case: step 24, image 1 of 1
    • Disconnect the white inverter cable connector from the right end of the board.
  25. Installing PowerBook G3 Lombard Lower Case: step 25, image 1 of 1
    • Disconnect the inverter plug, pulling directly up from the logic board.
  26. Installing PowerBook G3 Lombard Lower Case: step 26, image 1 of 1
  27. Installing PowerBook G3 Lombard Lower Case, Display: step 27, image 1 of 1
    • Turn the laptop around so that its back faces you.
    • Open the port door located at the back of the laptop.
    • Remove the four black Torx screws.
  28. Installing PowerBook G3 Lombard Lower Case: step 28, image 1 of 1
    • Hold the display on both sides and pull directly up until its hinges are free of their mounts.
  29. Installing PowerBook G3 Lombard Lower Case: step 29, image 1 of 1
  30. Installing PowerBook G3 Lombard Lower Case, Upper Case: step 30, image 1 of 1
    • Remove the three long silver and two short black Torx screws from the beige plastic casing.
  31. Installing PowerBook G3 Lombard Lower Case: step 31, image 1 of 1
    • Turn the Lombard so that the trackpad is nearest you and slide the thin plastic shield away from you, out from under the black casing.
    • Disconnect the newly revealed thin orange ribbon from the logic board, to the left of the trackpad.
    • Remove the two long silver Torx screws.
    • Turn the laptop over.
    • Remove the seven Torx screws from the bottom casing.
    • There are two long screws in the front left and front right corners; make sure to put these back in the proper place when reassembling.
    • Turn the laptop back over.
    • Remove the three short black Torx screws from the metal frame.
    • Remove the short black Torx screw to the far left that fastens the logic board to the casing.
    • There is a small black plastic spacer that goes between the bottom left screw and the logic board.
  32. Installing PowerBook G3 Lombard Lower Case: step 34, image 1 of 1
    • Grasp the upper plastic casing where it locks into the internal frame and pull back. When the plastic tab has cleared the slot that the casing locks into, pull up enough to keep it from locking back into place.
  33. Installing PowerBook G3 Lombard Lower Case: step 35, image 1 of 1
    • The PC card eject button on the laptop's left side prevents the upper casing from lifting up. In order to bypass the button, push it in far enough so that you can pull the upper casing's left side out and up beyond the button.
  34. Installing PowerBook G3 Lombard Lower Case: step 36, image 1 of 1
    • Lift the left side of the case partly up so that you can access and disconnect the audio in/out cables from the sound card in the upper right of the case.
    • Be careful not to lift the upper casing too far before you have disconnected the audio in/out cables or you may damage the sound card.
  35. Installing PowerBook G3 Lombard Lower Case: step 37, image 1 of 1
    • Remove the upper casing. Note that there are two tabs on the laptop's front that often cause the upper case to stick.
  36. Installing PowerBook G3 Lombard Lower Case: step 38, image 1 of 1
  37. Installing PowerBook G3 Lombard Lower Case, Power Card: step 39, image 1 of 1
    • Remove the two long silver Torx screws from the power card in the center of the laptop.
    • Grasp the power card near the black plastic shield and lift up.
  38. Installing PowerBook G3 Lombard Lower Case, Framework: step 40, image 1 of 1
    • Remove the single short black Torx screw anchoring the metal framework to the lower casing.
    • Use a five millimeter nut driver or needle-nose pliers to remove the small metal nut from the bolt in the laptop's back left corner.
    • If you're using pliers, be extremely careful not to let them slip or you may damage the logic board.
  39. Installing PowerBook G3 Lombard Lower Case: step 41, image 1 of 1
    • Disconnect the fan cable from the left side of the logic board.
  40. Installing PowerBook G3 Lombard Lower Case: step 42, image 1 of 1
    • Turn the laptop so that its back is facing you.
    • Lift up on the left side of the metal framework and remove the single black Torx screw.
  41. Installing PowerBook G3 Lombard Lower Case: step 43, image 1 of 1
    • Grasp the EMI Filter by its black end and rotate it toward the front of the laptop. Pull the filter up and beyond the screw bracket.
    • Remove the metal framework.
  42. Installing PowerBook G3 Lombard Lower Case: step 44, image 1 of 1
  43. Installing PowerBook G3 Lombard Lower Case, Sound Card: step 45, image 1 of 1
    • Lift the sound card out by pulling up on both the right and left sides.
    • If the sound card sticks, pull the black metal wall of the casing toward you while lifting the right side of the sound card up.
  44. Installing PowerBook G3 Lombard Lower Case, Logic Board: step 46, image 1 of 1
    • Turn the laptop around so that the front faces you.
    • Move the metal yoke to the left, making sure to leave the spring attached.
  45. Installing PowerBook G3 Lombard Lower Case: step 47, image 1 of 1
    • Gently lift the front edge of the logic board and then pull it toward you.
    • There are two major obstacles to avoid when removing the logic board: the first is the fan and connector cables, and the second is the bolt in the back left corner.
  46. Installing PowerBook G3 Lombard Lower Case, Lower Case: step 48, image 1 of 1
    • Lower case remains.
Attached Documents
iRobot
1 Reputation
636 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 3,314
