Installing PowerBook G3 Lombard Hard Drive
  1. Installing PowerBook G3 Lombard Hard Drive, Keyboard: step 1, image 1 of 1
    • Turn the computer so that the ports are facing you.
    • If the keyboard is locked, open the port cover and turn the keyboard locking screw until the keyboard is unlocked.
  2. Installing PowerBook G3 Lombard Hard Drive: step 2, image 1 of 1
    • Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
    • Make sure you have removed the laptop battery and CD/DVD module from the expansion bays before proceeding.
  3. Installing PowerBook G3 Lombard Hard Drive: step 3, image 1 of 1
    • Lift the keyboard out by pulling it up and away from you. Rest the keyboard, face down, on top of the trackpad.
    • In order to replace the keyboard, you must first remove the modem.
  4. Installing PowerBook G3 Lombard Hard Drive, Heat Shield: step 4, image 1 of 1
    • Remove the three silver Phillips screws that attach the heat shield to the internal metal framework.
  5. Installing PowerBook G3 Lombard Hard Drive: step 5, image 1 of 1
    • Lift the heat shield up and pull it toward you.
  6. Installing PowerBook G3 Lombard Hard Drive: step 6, image 1 of 1
    • Your laptop should look approximately like this.
  7. Installing PowerBook G3 Lombard Hard Drive, Modem: step 7, image 1 of 1
    • Remove the two silver Phillips screws from the modem.
  8. Installing PowerBook G3 Lombard Hard Drive: step 8, image 1 of 1
    • Use a spudger, the tips of your fingers, or a flat non-metal tool to get under the modem's edge and pry it up from its socket as shown in the picture.
  9. Installing PowerBook G3 Lombard Hard Drive: step 9, image 1 of 1
    • Disconnect the cable from the right side of the modem.
  10. Installing PowerBook G3 Lombard Hard Drive: step 10, image 1 of 1
  11. Installing PowerBook G3 Lombard Hard Drive, Processor: step 11, image 1 of 1
    • Use a spudger, the tips of your fingers, or a flat non-metal tool to pry up the processor's right side.
  12. Installing PowerBook G3 Lombard Hard Drive: step 12, image 1 of 1
    • Disconnect the keyboard cable from the logic board by pulling directly up on the clear plastic loop.
    • This step is out of sequence with the keyboard because in order to remove the keyboard you must first remove the modem.
  13. Installing PowerBook G3 Lombard Hard Drive: step 13, image 1 of 1
  14. Installing PowerBook G3 Lombard Hard Drive, Hard Drive: step 14, image 1 of 1
    • Grasp the orange cable at the left end of the hard drive and disconnect it from the logic board.
    • Try to grasp the cable on the plastic connector rather than on the flexible cable section.
  15. Installing PowerBook G3 Lombard Hard Drive: step 15, image 1 of 1
    • Grasp the plastic tab and pull the hard drive up and to the left, making sure that the metal bracket doesn't catch on the black plastic casing.
Attached Documents
iRobot
1 Reputation
636 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 4,615
