Installing PowerBook 3400 M3553 Speaker Panel
  1. Installing PowerBook 3400 M3553 Speaker Panel, Battery: step 1, image 1 of 1
    • Close the screen and turn the PowerBook over, orienting the computer upside down, using the label to guide you.
  2. Installing PowerBook 3400 M3553 Speaker Panel: step 2, image 1 of 2 Installing PowerBook 3400 M3553 Speaker Panel: step 2, image 2 of 2
    • Hold the button on the front left side and slide the battery out.
  3. Installing PowerBook 3400 M3553 Speaker Panel, Keyboard: step 3, image 1 of 1
    • With a Torx T8 screwdriver, remove the three Torx 24mm screws along the center of the back panel.
  4. Installing PowerBook 3400 M3553 Speaker Panel: step 4, image 1 of 3 Installing PowerBook 3400 M3553 Speaker Panel: step 4, image 2 of 3 Installing PowerBook 3400 M3553 Speaker Panel: step 4, image 3 of 3
    • Turn the computer over and open the display. You should see that the keyboard is loose.
    • Before attempting to remove the keyboard, note that a ribbon cable connects the keyboard to the logic board. Improper removal may damage your keyboard.
    • Slightly lift the front of the keyboard up, and slide the keyboard towards yourself.
    • Carefully lift the top half of the keyboard and pull it towards yourself.
  5. Installing PowerBook 3400 M3553 Speaker Panel: step 5, image 1 of 2 Installing PowerBook 3400 M3553 Speaker Panel: step 5, image 2 of 2
    • Loosen the ribbon cables connecting the keyboard to the computer by using a plastic opening tool to lift the tabs on either side of the cable port.
    • Gently remove the ribbons from its tabs.
  6. Installing PowerBook 3400 M3553 Speaker Panel, RAM: step 6, image 1 of 2 Installing PowerBook 3400 M3553 Speaker Panel, RAM: step 6, image 2 of 2
    • Gently wiggle the RAM card to loosen the connection until it pulls free.
  7. Installing PowerBook 3400 M3553 Speaker Panel, Speaker Panel: step 7, image 1 of 2 Installing PowerBook 3400 M3553 Speaker Panel, Speaker Panel: step 7, image 2 of 2
    • Disconnect the wires from the port.
  8. Installing PowerBook 3400 M3553 Speaker Panel: step 8, image 1 of 1
    • Remove the 7mm screw connecting the speaker panel to the computer.
  9. Installing PowerBook 3400 M3553 Speaker Panel: step 9, image 1 of 2 Installing PowerBook 3400 M3553 Speaker Panel: step 9, image 2 of 2
    • To detach the speaker panel's ribbon cable, use a plastic opening tool to lift the tabs on both sides of the cable port.
    • Once loose, pull the ribbon cable free.
  10. Installing PowerBook 3400 M3553 Speaker Panel: step 10, image 1 of 2 Installing PowerBook 3400 M3553 Speaker Panel: step 10, image 2 of 2
    • Lift the lighting/audio panel from it's bottom corners and pull the panel towards yourself.
Michael Mondragon
274 Reputation
9 Guides authored
Cal Poly, Team 24-59, Amido Spring 2011 Member of Cal Poly, Team 24-59, Amido Spring 2011
CPSU-AMIDO-S11S24G59
4 Members
9 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 14
All Time: 1,748
